Shifter help needed!!!!
Discussion in 'Technical' started by 510madmav, Mar 24, 2009.
  1. 510madmav
    510madmav Member
    San Francisco bay area
    1973 Maverick
    today was my first day to take the car for a spin with headers, open headers. i could not shift to 2nd or low gears, it would not move, i have the factory 3 speed on the floor.. also i removed the linkage which attatches to the steering column to the trans. what is that linkage for? i think it has something to do with why my key sometimes gets locked in the ignition. some one please clarify with me whats happening. thank you
  2. veetwelve
    veetwelve Member
    Airdrie Alberta Canada
    `72 Comet GT
    To my knowledge, the only reason for the column linkage would be the fact that the floor shift was an option. I would assume that the linkage to the column shift would have been installed in every car.
    I have removed mine this year, so I hope i don't have issues too.
    As for the shifting... not sure what the problem would be, maybe the linkage is hung up on the header or something like that.
  3. 510madmav
    510madmav Member
    1973 Maverick
    yes, i found why it wasn't shifting, it was getting hung up on the firewall. i found out the linkage is for a key ignition lock sort of thing. not sure what the correct terms are.
  4. 71gold
    it may also...lock the steering...:yup: i had to lock mine in the park position so it would have the..nuteral/safty switch...and not lock the steering while driving...again...:rolleyes:
    ...Frank...:tiphat:
  5. 510madmav
    510madmav Member
    1973 Maverick
    what did you lock in park? the bracket on the column where this linkage attatches? how did you lock it? pics? thanks
  6. 71gold
    tac welded...:yup:...the first time and took the guts out when i went to...Rack-n-pinion...:thumbs2:
    ...:cool:...
  7. 510madmav
    510madmav Member
    1973 Maverick
    what did you weld? now that the linkage is removed, i can shift through the gears when cars off.
