Shift linkage hell
Discussion in 'Technical' started by chase259, May 16, 2014.
  1. chase259
    chase259 Member
    Calgary, AB, CAN
    1970 ford maverick
    So I just installed my hooker headers and now my shift linkage won't fit back on is there anything I can do to make it work?
  2. yellow75
    Tillamook Oregon
    Floor shifter
  3. chase259
    chase259 Member
    Calgary, AB, CAN
    1970 ford maverick
    I know but I am going as stock as possible and I heard whispers of an allusive cable shifter
  4. mercgt73
    mercgt73 Member
  5. baddad457
    What kind of shifter do you have now ? Auto, manual ? Floor or column ?
  6. chase259
    chase259 Member
    Calgary, AB, CAN
    1970 ford maverick
    It's a 3 speed auto column shifter
  7. baddad457
    Yea, that's not going to work with headers.
  8. Eastern Raider
    Eastern Raider Member
    middle Ga. warner robins
    Look into Electric shifters as in solenoid shift. The 2014 charger uses one. You would probably have to be creative, hope this helps.(y)
  9. chase259
    chase259 Member
    Calgary, AB, CAN
    1970 ford maverick
    So what are people's recommendations for floor shifters? I have a 71 mav with a 302 swap
  10. chase259
    chase259 Member
    Calgary, AB, CAN
    1970 ford maverick
  11. Dave B
  12. WA8DDN
    WA8DDN Member
    Malvern, Ohio
    '74 Grabber, 302,C4,3:80 to 1 Traction lock. 1973 V8 car,LDO
    I have a B&M Quick Silver shifter in my '74. It is a ratchet shifter. I like it because as you ratchet from neutral to low the stick remains in the center position. To go up thru the gears you just bang the stick forward.
  13. chase259
    chase259 Member
    Calgary, AB, CAN
    1970 ford maverick
    Oh...so who should I buy it from...?
  14. chase259
    chase259 Member
    Calgary, AB, CAN
    1970 ford maverick
    Lokar or American shifters
  15. Dave B
    Lokar makes pretty good stuff, I wounldnt think twice about buying anything from them.
