sequential lights
Discussion in 'General Maverick/Comet' started by biggruss, Oct 30, 2013.
  1. biggruss
    biggruss Member
    picayune,ms.
    1970 maverick grabber,1975 maverick (parts car)
    I want to hook up the sequential lights on my mav. I have the t bird lights and the web electronics stuff but I did a search and saw where some have run a extra wire and relays for more power. my question is what relays and size wire do I need and how to hook them up? if anyone has any pics of theirs that would help out a lot. thanks in advance russell
  2. doncomfort
    chillicothe oh
    I used my the factory wire and fuse with no trouble.
  3. biggruss
    biggruss Member
    picayune,ms.
    are your brake lights bright? that's why I was asking about the relays and stuff but if yours works good I'll do that. thanks russell
  4. qpdcqp
    qpdcqp Davon
    Yuba City Ca.
    70 Grabber Maverick, 75 2dr maverick
    You should post pictures of the whole process and of the finished product :camera::camera:(y)
  5. doncomfort
    chillicothe oh
    Yes, they are bright. Check with 71gold, he is running the same set up as me.
  6. bmcdaniel
    bmcdaniel Senile Member
    I used the factory wire but the circuit breakers in my light switch didn't like the extra current. I jumpered out the internal circuit breakers and installed higher current external breakers. Three breakers, one each for marker/tail lights, headlights, and brake lights.
  7. biggruss
    biggruss Member
    picayune,ms.
    so do I use the factory wire or do I need the relays for more power? :hmmm: :huh:
  8. bmcdaniel
    The wire to the brake lights, at least in my car, is 16 AWG. The bright filaments of 1157 bulbs draw about 1.5 amps each for a total draw of nine or so amps. Well within the ampacity of 16 AWG as long as the wire is in good shape and you have good grounds. Speaking of grounds, I also added ground wires from each light housing to a bare spot on the trunk latch support for better grounding.
