seat belts
Discussion in 'General Maverick/Comet' started by scs, Mar 25, 2016.
  1. scs
    scs Member
    Prescott wisconsin
    1972 Maverick Grabber
    I have researched the best 3 point front seatbelts for this car, and no posts get very specific with part numbers. Can anyone provide a source for a good generic 3 point retractable front belt that fits good for a 1972 Maverick with high back seats? This is a good sign I am getting near the end of this project!!!!!!. Thanks
  2. 71Mavrk
    71Mavrk Member
    Nevada
    You're going to have a tough time with that. I did not like what I have seen retrofitted into these cars.
    I grafted '74 belts into the floor pan and welded in the matching overhead mount. The stock overhead mount on a '72 is pretty far back especially for high back seats. Also, the corresponding tunnel side mounts on a '72 are further back than a '74. Unfortunately, this is too late for you.
    Micah
  3. groberts101
    groberts101 Member
    Minneapolis, MN
    Sorry I don;t have an answer for the question here but it must finally be nice to see such a bright light speeding towards you as you drive out of the tunnel. And don't forget that I enjoy racing neighbors too! :evilsmile:
  4. CaptainComet
    I got a pair of belts from Auto-loc. They are just OK, but you may want to keep shopping for better.
    My reason for posting is to show the seat belt drop I used. These are out of a mid-90s Ford church van. They place the belt at a better angle, using the stock upper mount, and don't look out-of-place.
  5. groberts101
    groberts101 Member
    Minneapolis, MN
    those are interesting, Jeff. Do you ever hear them tapping against the windows during aggressive cornering?
  6. CaptainComet
    That would only be a possibility if my car ever moves under it's own power again ...LOL.
    In reality, I doubt that would ever be a problem. They really only move front-to-back, not much side-to-side, and they will have a belt laced through each. With the belt in there, they also will be drawn forward at a bit of a forward angle.
  7. 71Mavrk
    71Mavrk Member
    Nevada
    '74 belts grafted into my '71.
    Micah
    rotorr22 likes this.
  8. scs
    scs Member
    Prescott wisconsin
    Nice, that looks about as good as it can get! I have been talking with member Dyent and will probably order what he has suggested from seatbeltplanet. It should end up looking something like what Captain Comet posted above, but a complete kit and ready to bolt in.
    What is that piece of plastic down by the floor attachments? I have not seen that one on my 72 Maverick, am I missing another part again?
  9. gregmaverick
    gregmaverick Member
    Salem, OR
    1970 maverick
  10. Craig Selvey
    That is a 1974-1977 thing.
  11. 71Mavrk
    71Mavrk Member
    Nevada
    SCS,
    If you go to my Showcase post you can see how I cut up the floor and grafted the seatbelt mounting plate into the sill. The seatbelt retractors are inside the sill. The plastic piece covers the assembly. It was a bit of work, but I have a proper three point assembly.
    Micah
  12. groberts101
    groberts101 Member
    Minneapolis, MN
    Thanks much guys. Was looking at the conversion myself and learned a lot from the community in one single page. (y)
  13. 55crownvic
    55crownvic Member
    colorado springs
    I welded a plate with a nut into the "B" pillar, about halfway down the quarter window opening, and attached mine there. But in my case, I mounted the retracting part, in the bottom of the "B" pillar, behind the inner quarter trim panel. Then cut a slot in the trim panel for the belt to go thru and used a maverick belt piece for the new belt to go thru. It works really good, and I like the location. I may have to get a few pics of it to post here.
