scary situation
Discussion in 'General Maverick/Comet' started by HOMERMAV, Aug 7, 2010.
  1. HOMERMAV
    HOMERMAV Member
    NW.OHIO
    1971 MAVERICK
    last week i heard some noise coming from my valvetrain and the mav wasnt running too good so i removed the air cleaner and started to hear some metal noises coming from valve cover i thought oh no i got some loose rocker arms.so i pulled the cover and low and behold there was the baffle plate from my new valve covers laying on my rocker arms both aluminum rivots came out and the search was on where did they go? into the oil pan!!!!! thats where i found them.spent the last two days working on it and got everything back together today.found some fouled plugs so i replaced all of them and its running real good now as for the valve covers i left them off for now and put my old chrome ones back on until i talk to the company the made my covers. they were only 3 months old.thank god they didnt get into my valves or springs. ok im done ranting and venting. anyone else have this happen?
    john
  2. Stingrayiii
    Stingrayiii Member
    Las Vegas
    1973 Ford Maverick 302/auto
    Wow that is crazy! I have dropped stuff down in engines before. Really torq's ya when that happens.
  3. maverick maniac
    maverick maniac Banned
    owensboro ky
    it seems that with a lot of company's today thy don't have enough
    time to do it right ,but all way's have enough time to do it over ,,,,
  4. yellow75
    Tillamook Oregon
    Count your blessings, I have seen some bad damage due to this very problem. If I ever have baffles I put the screws in with some locktite.
  5. HOMERMAV
    HOMERMAV Member
    NW.OHIO
    1971 MAVERICK
    oh yeah i was a wreak until i found the rivits
  6. HOMERMAV
    HOMERMAV Member
    NW.OHIO
    1971 MAVERICK
    there going to get an earfull from me monday
  7. HOMERMAV
    HOMERMAV Member
    NW.OHIO
    1971 MAVERICK
    lesson learned mike but they were not screws they were spiraled rivits you tap in and they were nice and tight when i installed them. hopefully they make it right with me.
    john
  8. strokermaverick
    strokermaverick Member
    What do you expect them to do to make it right?
  9. darren
    Good news is there way to big to fit through the pump screen, but they could have got in the valvetrain. I suspect the company wont do much about it.
  10. HOMERMAV
    HOMERMAV Member
    NW.OHIO
    1971 MAVERICK
    dont know, but i do know i didnt put there covers back on.maybe refund? we will see come monday.but i do know i need to let them know what happend so maybe they can correct the problem as im sure it has not only happened to me.
  11. HOMERMAV
    HOMERMAV Member
    NW.OHIO
    1971 MAVERICK
    darrin thats what i thought about the valvetrain lucky for me they didnt and i would hope if there a stand up company they would make a good faith gesture.
  12. Bryant
    what brand valve covers are those?
  13. HOMERMAV
    HOMERMAV Member
    NW.OHIO
    1971 MAVERICK
    not the ones in my avatar i put a new set on about 3 months ago.not going to say right now dont want to cause any ruckus but they are a well known brand.need to at least give them a chance to respond.
  14. Dfitzman
    Dfitzman Member
    Taxachusetts
    1971 Green Machine
    "cough. summi, cough" lol j/k better not be FR ! any how from an engineering and fastener standpoint I have used these screw rivets on motor boilerplates in cast alum housings for the oil drilling industry. These rig motors produce 1200 hp 4000 lb ft tourque and vibrate like crazy. I have seen these motors back from field in arctic type environments for 5 years and never seen even a loose rivet. short of having too large a diameter hole during manufacture these should never loosen. They are also close to a grade 8 hardness.
    Any ways good detective work tracking down the sound you probably saved your valvetrain and possibly engine.
    hmm I just started refurbishing my "84gt powered by ford V/C's for my engine build better check them :yup:
  15. HOMERMAV
    HOMERMAV Member
    NW.OHIO
    1971 MAVERICK
    none of the above but i had a set of factory ford v/c that are in my avatar and they had screws to hold the baffle in. you could be right about the overbore
