Rusted Sending Unit
Discussion in 'Technical' started by maverick?, Apr 26, 2006.
  1. maverick?
    maverick? Member
    Southwest Missouri
    1973 Maverick 2dr, 1973 Maverick 4dr LDO
    Last night while trying to get my Mav running we found that the sending unit in the gas tank was shot. The gas tank itself might be trashed enough also that I need a new one. I can't get a sending unit from the local auto shops so I guess that leaves me with hunting a salvaged car or buying an aftermarket. What are some good aftermarket tanks for my Mav? Anyone here have a tank in decent shape with a decent sending unit that they would sell?
  2. Earl Branham
    Lugoff, SC
    I think you can order the sending unit from AutoKrafters ( autokrafters.com )
  3. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    Top ... right side of screen ... SEARCH button ...
  4. igo1090
    igo1090 Member
    catonsville, md
    mavaholic has a great article on here about putting an early mustang tank & sender in. i did & it was fairly easy, cheaper, & gives equal space for exhaust on both sides of the tank. do a search.
  5. maverick?
    maverick? Member
    Southwest Missouri
    Will a 1970 sending unit work on a 1973?
  6. scooper77515
    I promise that if you look on ebay, you will see an unlimited supply of them.
    As for the tank, a little harder to come by.
    I took mine off and filled it full of fish tank gravel and shook the crap out of it for a few hours (if I was at the ranch, I would have attached it to the cement mixer and let it tumble for a while). Then get all the rocks out when all the big chunks of rust are knocked loose. Then check this place out www.hirschauto.com for a $35 kit that has an "etcher" and an epoxy coating for the tank. I used one quart of the epoxy, but I would recommend using two quarts. This will line your tank with a white epoxy coating to prevent any future rust. Never had any rust in my fuel line since, and that was about 3 or 4 years ago.
  7. dmhines
    Cumming, GA
    If the tank isn't too far gone a radiator shop can boil it out and seal it ...
  8. streetrod77
    streetrod77 Member
    Memphis,Tenn
    77 comet
    Try http://www.gastanks.com/ for the tank. Call John Wolf at (440)942-0083 to get your old sending unit working again.
  9. scooper77515
    Gastanks.com is great, but only if you have a '75 or newer maverick... :huh:
    That is all they offer.
  10. Mavaholic
  11. streetrod77
    streetrod77 Member
    Memphis,Tenn
    77 comet
    Thanks for the info Scooper, I didn't know that.
  12. hotrod-daddy
    hotrod-daddy Member
    Rock Springs,Wyoming
    a 1971 Grabber with a 302/351
    I have used the "Kreem" brand to clean,etch and seal my fuel tank...took every bit of 8 hours.
