rpm
Discussion in 'General Maverick/Comet' started by 48fordnut, Apr 1, 2008.
  1. 48fordnut
    48fordnut Member
    mid ga
    I need to know what rpm you are turning with a std tire at 60 mph with a 2.79 gear. thanks, jim. non o/d trans.
  2. bmcdaniel
  3. 48fordnut
    48fordnut Member
    mid ga
    thanks ,that was exactally what i needed. jim.
  4. PaulS
    You do realize that that number is only approximate with an automatic transmission don't you? The torque converter can cause variations of RPM up to 1000 RPM with a stock converter and more with a high stall converter. (depending on speed and engine)
  5. 48fordnut
    48fordnut Member
    mid ga
    thanks for the insight.:)
