rocker arm shims pedestol
Discussion in 'Technical' started by justin has a 74, Aug 16, 2010.
  1. justin has a 74
    kentucky
    Trying to figure out if shims on my rocker arms would make my rockers tighten down more to reach my push rods or would it raise the height or my rocker arms.
    So basically would it raise my rocker arms or lower them?
    Im not thinking tonight, cant figure it out:16suspect
  2. svthauln
    svthauln Member
    Mounds,Ok
    1972 maverick
    Raise them, If you are running the trick flow cam in your sig it has a smaller base circle than the ford cams therefore you have to use longer pushrods with shims
