rockauto.com discount
Discussion in 'General Maverick/Comet' started by Maverick Dan, Mar 2, 2006.
  1. Maverick Dan
    Maverick Dan Member
    Greenbrier, AR
    72 2 dr Mav, 74 Comet, restoring
    A while back I asked about a good place online to buy suspension parts. Jayman suggested www.rockauto.com. I ended up buying about $600.00 worth of Moog parts from them. Prices were very good and service was great. I just received an email from them with a discount code. I thought I would pass it on in case anyone was looking to buy some parts. It's only 5%, but every little bit helps. Here's the info:
    Thank you for being a www.RockAuto.com customer!
    To show our appreciation, we would like to give you and your friends a special discount on auto parts.
    Here's how it works:
    - You give the following discount code to friends, neighbors, relatives, the guy at the corner garage--anyone you know who works on cars or trucks:
    384511359788
    - When someone (including yourself) places an order at
    www.rockauto.com and enters your discount code, he or she will receive an immediate 5% discount on that order.
    * If you are using our Java Catalog, enter your discount code in the "How did you hear about us" line of the shopping cart
    * If you are using our non-Java Catalog, enter your the discount code in the "Discount Code" field of the Shopping Cart and click "Calculate Discount"
    - The discount code expires on May 2, 2006; so don't wait!
    You may use this discount code as often as you wish until it expires, but only one discount code can be used per order.
    **Each month we see people who put the word "discount" in front of their code and do not get the discount. Please enter ONLY the discount code.**
  2. streetrod77
    streetrod77 Member
    Memphis,Tenn
    77 comet
    Thanks Dan, What parts did you order?
  3. Maverick Dan
    Maverick Dan Member
    Greenbrier, AR
    Here's a list of what I ordered. I couldn't insert an Excel Spreadsheet, so the formatting is off a bit, but I think you can see what you need to.
    Vendor Qty Manufacturer Descripton Part number Price Extended Price
    rockauto.com 2 Moog Outer tie rod end ES445RL 17.33 34.66
    rockauto.com 2 Moog Inner tie rod end ES387L 42.99 85.98
    rockauto.com 1 Moog Idler arm bushing kit K8103 8.15 8.15
    rockauto.com 2 Moog Lower control arm K8123 47.79 95.58
    rockauto.com 2 Moog Upper control arm shaft kit K8131 45.89 91.78
    rockauto.com 1 Moog Strut rod bushing kit K8157 32.79 32.79
    rockauto.com 1 Moog Stab. Bar to frame bushing kit K5227 5.25 5.25
    rockauto.com 2 Moog Stab. Bar link kit K8097 5.83 11.66
    rockauto.com 2 Moog Upper ball joint K8142 23.79 47.58
    rockauto.com 2 Moog Rear leaf bushing K8785 8.89 17.78
    rockauto.com 2 KYB Front shock - Gas-A-Just KG4517 35.79 71.58
    rockauto.com 2 KYB Rear shock 343136 20.79 41.58
  4. streetrod77
    streetrod77 Member
    Memphis,Tenn
    77 comet
    Yea, I need to replace a few parts that didn't come in the frontend kit. Plus I still have a little play in the steering, but I think I need to replace the center link bar(that bar in the center that connects both wheels). I guess its called that. Thanks again
  5. don graham
    thanks for the info:)
  6. Mavaholic
    Looks good I might try their leaf spring shackle bushings. The ones I have are too small.
  7. bmcdaniel
    I've bought from Rockauto four times now. Good prices but they've screwed up my order three of those times. I keep going back 'cause I'm cheap. :D
