Ring and Pinion Sets for 1974 maverick
Discussion in 'Technical' started by revatoons, Nov 19, 2008.
  1. revatoons
    revatoons Member
    Venezuela
    Maverick 74
    Hi, I want install a new Ring and Pinion Sets in my 1974 Ford Maverick, but is very hard find a new part I dont know where, are you know where I can buy?
    Which is the better Ring and Pinion Sets for my car, there are a other Ring and Pinion Sets of the other car that I can install in my Maverick?
    There are a better Ring and Pinion Sets that give more power at my car?
    Thanks!!!!!!!!!!!
  2. don graham
    The ring and pinion gears will not give you more power, but will help you use what you've got more efficiently. The gear ratio will depend on what you want to use the car for. Drag Racing go to a lower gear. I have 4.33's in mine. I run 1/4 mile. To use on the street I wouldn't go any lower than a 3.50, but that's just my opinion. They are available new from Summit racing or Jegs. Lots of them show up on ebay. Make sure you get the right ones for your rear end. The 74 came with an 8 inch rear.:)
  3. Bryant
    i can get you any ratio you need. i have both new and good used gear sets for the 8" at my shop. my number is in my sig if your interested.
  4. revatoons
    revatoons Member
    Venezuela
    Maverick 74
    thanks, i will contact you soon
  5. DeJacks
    DeJacks Member
    Lemoore, CA
    1970 Ford Maverick
    I've been meaning to call you Bryant!
  6. rthomas771
  7. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    He's in Venezuela, does his car have an 8" or the odd 8.5"?
