Reverse switch power
Discussion in 'General Maverick/Comet' started by alaskamaverick, Nov 2, 2016.
  1. alaskamaverick
    alaskamaverick Member
    Spokane, WA
    I cannot figure out why I'm not getting power to my Reverse switch. I've unplugged the switch and checked power at the connector...NO POWER. Fuse is good.
    1970 Maverick converted from column shift to floor shift
    All of the other lights work
    Any ideas
    Thank you,
    Mark
  2. 71gold
    broken or bad connection in the wire going to the switch.
  3. gregmaverick
    gregmaverick Member
    Salem, OR
    1970 maverick
    Power to the Back-Up Lamp switch is a Pig-Tail to the Radio Power. Perhaps it came off...?
    See attached wiring diagram.
  4. alaskamaverick
    Spokane, WA
    You're correct in the sense it came off. It's not installed yet.
    I will temp install it and see what happens.
    Thanks for the knowledge, greatly appreciated
    Mark
  5. alaskamaverick
    Spokane, WA
    OK, so I thought it was going to be easy, got up under the dash and found a group of 3 wires, yellow/black, blue/red and black/red. None have connectors, stripped wires.
    Reading on the forum I see the yellow/black and the blue/red wires go to the radio.
    Any idea where the black/red wire go to?
    Thank you,
    Mark
  6. gregmaverick
    gregmaverick Member
    Salem, OR
    1970 maverick
    See attached PDF. Look at 2nd page, upper left. You'll see a square unmarked box (should say back-up switch), it connects to the Radio wire (very small print). The other side connects to the back-up lights. The schematic details the wire colors.
  7. alaskamaverick
    Spokane, WA
    so should the black/red wire and the yellow/black wire be together/connected
  8. gregmaverick
    gregmaverick Member
    Salem, OR
    1970 maverick
    Yes. I am assuming that whomever cut the wires - only did that (didn't make any other connections to anything else, for some other modification).
    Did you measure any power on the wire(s) - when the key was in ON or ACC position?
  9. yellow75
    Tillamook Oregon
    At the fuse panel the windshield wiper switch and the radio/back up light power are on the same fuse
  10. alaskamaverick
    Spokane, WA
    :yahoo:I ( WE, THANK YOU GREGMAVERICK ) GOT THE REVERSE LIGHTS TO WORK!!!!!:yahoo:
    10 Volts
    Now all of the lights are working. man those dash lights are less than desirable, no wonder people switch those out
    Thanks again gregmaverick
  11. Maverocket
    Maverocket Bob Williams
    Northwest
    69.5 Mav, 62 F100 unibody
    Does this mean you're road worthy now?
  12. alaskamaverick
    Spokane, WA
    I'm getting there Bob, I need a new gas sending unit, wheels/tires and a front end alignment.
    In the mean time I will double check things.
    I appreciate your help too, you learned (taught) me a lot(y)
  13. gregmaverick
    gregmaverick Member
    Salem, OR
    1970 maverick
    You're welcome! :tiphat:
