retrofit 1965 mustang ignition
Discussion in 'General Maverick/Comet' started by xpsnake, Feb 14, 2005.
  1. xpsnake
    xpsnake Bruce
    Maryville, IL (near STL)
    1971 Ford Maverick 2-door
    I'm going to be retrofitting a 1965 mustang ignition into my dashboard, I got a used unit with harness and a new lock cylinder. I can't figure out how to get the new lock cylinder in, does anyone know what position must the lock be in to be installed?
  2. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    Are you referring to the ignition switch?
    For a '65 Mustang it was mounted on the dash.
    I am not sure but they are probably totally different
    in the wiring and I doubt that it is an easy switch.
    But hey, I've been wrong plenty of times before.
    Perhaps someone here knows.
    Good luck with the switch.
    Seth
  3. xpsnake
    xpsnake Bruce
    Seth,
    I am doing a dash-ignition in my car, welding up the ashtray for the cylinder placement, I just need to find someone who knows about these old ford ignition cylinders.
  4. maverick1970
    maverick1970 MCG State Rep
    Missouri
  5. xpsnake
    xpsnake Bruce
    Thanks, I found that article from a Mustang Board last night as well, I still can't get the darned lock cylinder to fall into place, this sucks.
  6. maverick1970
    Missouri
    Make sure the switch is in the proper position. Using a flat blade screwdriver inserted into the slot of the switch make sure it is in the ACC position (should be all the way CCW)
  7. xpsnake
    xpsnake Bruce
    I got it, the new cylinder had a flashing on it that I had to file down a bit, this is going to look GREAT on my dash.
  8. maverick1970
    Missouri
    Post some pics when you get it done
  9. xpsnake
    xpsnake Bruce
    I definately will, the car won't be out of the body shop until late may though.
  10. stockhatch
    stockhatch Re Member
    Boiling Spring Lakes NC
    '72 Grabber
    Im interested too. My ignition switch wont lock any more so I need to replace it. I was going to try and find a 69.5 unit to put in my car, but we know how impossible they are to find.
    AC
  11. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    StockHatch ... there has been a 69.5 switch and bezel on eBay over and over again for weeks ... NOS ... switch for $9.95 and Bezel for $25 .... I was think about it but I don't have a 69.5 column so it wouldn't look right and don't feel like messing with the wiring ....
  12. xpsnake
    xpsnake Bruce
    The wiring is pretty simple, there's only 3 or 4 wires running to either switch. I am going to take my stock column cover and use it as a base to shave and fiberglass smooth.
  13. stockhatch
    '72 Grabber
    Oooooh! Thanks. Ill check that out :bananaman
    AC
    EDIT: found the bezel, but not the switch
  14. dmhines
    Cumming, GA
  15. dmhines
    Cumming, GA
    I think there is also a bracket that mounts below the dash to hold it all in place. I couldn't find the part numbe for that. I also couldn't find the one for $9.95 so I guess he gave up relisting it ..
