Replacing upper ball joints
Discussion in 'Technical' started by welch1jim, Oct 28, 2008.
  1. welch1jim
    welch1jim Maverick-iac
    Massachusetts
    1976 Maverick 302
    I am researching to get some advice on replacing my upper ball joints. So far, I have decided to use Moog parts and found a couple of reasonable sources (woodys-auto-supply.com).
    My car still has the original rivets retaining the ball joints. What tools/techniques are most useful to remove the rivets? I understand the innermost rivet (center position) is difficult to reach. I was thinking of drilling out the rivets with a right-angle drill and a short bit. Other ideas? Experience?
    Thanks.
  2. maverick1970
    maverick1970 MCG State Rep
    Missouri
    You can check www.rockauto.com for parts as well. You can use a Dremel tool to grind down the rivets as well.
  3. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    I grinded mine down.
    I used MOOG as well
  4. welch1jim
    Massachusetts
    1976 Maverick 302
    What style of grinder did you use? Pneumatic? Electric? Right angle grinder? What size disk? etc.
    Thanks.
  5. mean_maverick
    ive grinded several down using both an pneumatic angle grinder and an electric right angle grinder. both i believe had 4" discs...
  6. PINKY
    Louisville, Ky.
    1970 Ford Maverick
    ditto.
    I actually remember starting to drill them out.....that got old quick!
    Steady with a grinder was much fast and it got the job done.
  7. lilfarley
    lilfarley Chris Comley
    Central City, Iowa
    those look great
