Replacing Shift Shaft Seal w/o removing Transmission
Discussion in 'Technical' started by driftless71, May 30, 2025.
  1. driftless71
    driftless71 Member
    De Soto, WI
    1973 Comet GT
    Has anyone replaced the Shift Shaft Seal on a C4 while the transmission is still in a working car? It looks to me that the 2-3 inches of clearance will not allow me to tap in a new one. I really do not want to drop the tranny just to replace that seal.
  2. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    I did it with it still in the car. Installed a Trans-go shift kit at the same time, so the valve body was out. I used a nut & bolt with 2 large washers to seat the seal. Kind-of-a homemade redneck press.
    TeeEl likes this.
  3. driftless71
    driftless71 Member
    De Soto, WI
    1973 Comet GT
    Thanks! Love it. Sometimes an obvious solution escapes me! Will do today.
  4. TeeEl
    TeeEl Senior Member
    Colorado
    I appreciate this thread, as I also need to replace mine...
    driftless71 likes this.
