removing steering column
Discussion in 'Technical' started by Dan Greenbaum, Sep 29, 2002.
  1. Dan Greenbaum
    Dan Greenbaum Member
    1977 Maverick
    Hi, I just came in from the driveway b/c i'm stuck. I'm trying to remove the steering colunm from my mav. Its almost all disconnected. I just cant seem to figure out how to separate the tranny linkage from the base of the column. It seems to be pressed through a plastic retainer. any suggestions?
    Thank you, Dan
  2. Dan Greenbaum
    1977 Maverick
    I got my answer. Thanks anyway.
  3. '72 Comet GT
    '72 Comet GT getting there
    Atlanta GA
    green 72 Comet GT
    Enlighten me?
    Ok, I'll be swapping out my steering column in the future so I wanted to know any problems you ran into during the swap.
  4. mark_b
    mark_b Member
    western PA.
    73 all original 302 2d red blk int. 72,302.2dr. green and 71 200ci. 2d green
    The little plastic retainers...
    The way I have removed them in the past is to heat them up with a paint stripper gun. This makes them plyable. Then when there good and hot pry off the link.
    Anyone, If there is a more civilized way, let me know.
    This is the only way I know of. Mark
  5. Dan Greenbaum
    1977 Maverick
    This is the reply I got from Old Guy:
    "Ford has a special tool that looks like a pair of slip joint pliers with vise grip slotted jaws on top and bottom and an adjustable bolt on top. They press the rod out of the bushing and then you have to cut the bushing out of the lever and install the new one on the rod and use the bolt device as a gage and install back into lever. Just force the rod out with vise grips or ?? and reinsert with small hole drilled for cotter pin etc, to use the old bushing over if it's good shape.
    __________________
    OLD GUY-Dave H. "
    I Used the Vise Grip method and it woked out fine.
    Dan
