Removing Grabber Side Mirror
Discussion in 'Technical' started by kukm66, Jan 29, 2008.
  1. kukm66
    kukm66 Member
    Phoenix
    1972 Grabber, 1964 Falcon Futura Convertible, 1964 Ranchero
    The mounting base on my driver's side mirror is busted. It is currently hanging by the 3 cables. The door is gutted right now so there is easy access. I started to remove the actual mirror part by removing the 2 screws holding it into the housing. The cables are attached to a small rectangular plate but from the looks and feel, they are they to stay without damaging the parts. So that leaves going to the other end and removing the assembly from the door. Is this the correct way to replace the base? If so, what are the steps to remove the components from the door panel? I will have to replace the knob as it is missing or broke off. The bezel is intact but does not want to unscrew from the door panel.Who had done this before?
  2. maverick1970
    maverick1970 MCG State Rep
    Missouri
    You will need to remove it from the interior side/adjuster handle end. The Bezel is threaded onto the adjuster. There are some internal slots cut into the bezel to assist.
