Removing glass trim
Discussion in 'General Maverick/Comet' started by Gene Fiore, Dec 7, 2013.
  1. Gene Fiore
    Gene Fiore Member
    Goodyear, AZ
    Was at a junkyard today and found a 72 mav with nice front and rear glass trim but I didn't know how to properly remove them without damaging them. :huh: How do you do it?
  2. Dave B
    You need a special tool for it, there have been threads on it before.
  3. scooper77515
  4. Paul Masson
    1971 Grabber
    Plus a lot of patience and a firm, yet gentle hand!
  5. Acornridgeman
    Wisconsin
    Gene, since you are in Arizona, that will work to your benefit. The clips release much easier when the temperature is quite warm as it softens the window sealer the clips are often buried in. If you would be trying to do this in the north right now you would find it next to impossible unless the car were in a well heated shop.
    Use the tool to release the clip and never pry on the trim itself or you will dent it. A lot depends on how much sealer was used to assemble the glass. Sometimes it can be very hard to even find the clips. Other times they just pop right off.
    Hope this helps .............. :)
  6. Gene Fiore
    Gene Fiore Member
    Goodyear, AZ
    Thanks for all the tips...I really would like to snag this trim if not for me for someone else that might need it.
  7. ESampson
    ESampson Member
    Nanaimo, BC
    1974 Comet GT
    Take your time.. That's basically the only tips I can give.. It does get frustrating if it has been filled with butyl, just don't force it
  8. Gene Fiore
    Gene Fiore Member
    Goodyear, AZ
    Should I snag the clips too?
  9. Cruzin Illusion
    Cruzin Illusion Enigma
    Commerce City, Colorado
    1972 Grabber
    If you can get them I would. You can buy repoped clips but from the feedback I hear the OEM ones are better.
  10. scooper77515
    Wear leather gloves.
    I removed 4 or 5 sets of trim from a junkyard once, and I had no knuckles left on the hand I used the tool with. The rocking motion will scrape your fingers against the glass. And old dirty glass is NOT smooth.
  11. Moneymaker 1
    Panama City Florida
    If you decide to get the clips also, PB Blaster cleans them up nicely, it will also get the butyl off of your hands and the trim.
  12. Dave B
    Grab as many of the clips as you can, and if the car is still original, make note of any green clips, which might be in the corners, where all the others will be yellow.
  13. scooper77515
    What is the deal with green clips?
  14. scooper77515
    When you reinstall them on your car, do not skip any clips, or you will lose a piece of trim at 65 mph.
    Wanna know how I know?
    That is why I grabbed 5 sets of trim when I had access to them.
  15. ESampson
    ESampson Member
    Nanaimo, BC
    1974 Comet GT
    Don't use weak clips either... Lost mine going down the 1/4 mile :(
