removing a harmonic balancer
Discussion in 'Technical' started by pipman76, Apr 20, 2010.
  1. pipman76
    pipman76 Member
    alabama
    1972 mav
    guys i need to know how i can remove my balancer on a 5.0 engine it still has the flywheel attached but no tranny i have no help so with the puller in place how to i keep the engine from turning as i try to start removing i need tips
  2. sam03rc
    sam03rc Member
    gates county, nc
    1972 maverick 302 C4
    well if the motor is pulled from the car take one of the bolts on the flywheel and back it out about half-way enough so you can take a wrench and hold it on a bolt across from the one you backed out then ( if you have another person there) have a breaker bar on that wrench if you have no one to help there you can turn the engine over till the breaker bar on the ground and then have another breaker bar on the bolt on the harmonic balancer then you will be able to loosen the center bolt but leave it in the threads so when you use a puller you dont damage the threads. i hope this helps this is how i took mine out
  3. yellow75
    Tillamook Oregon
    Do any of the holes go all the way through the flywheel, if so you could stick something through it and it would jam up on back side of block, or you could pull a spark plug and stick some rope in the hole so the piston will act as a stop. Impact wrench would be the easiest though
  4. justin has a 74
    kentucky
    pipe wrench works nice, it holds that sucker still
  5. diddie
    diddie Member
    indiana
    two 1977 Maverick 2drs.
    If the guide pin is still in the block you can put a prybar into fly-wheel teeth and against guide pin to hold crankshaft as you crank down on your puller bolt (additional person would be helpfull!) If you want i could stop by and help. of corse it will be first of Nov. before i'll be through Alabama!:beerchug:
  6. Joe Dirt
    make sure to remove the center bolt
  7. ptpdub
    ptpdub Member
    canada Sk.
    take some very clean soft rope and incert a foot of it in the sparkplug hole on a piston on compression stroke. then roatate the engine till the pistin pushes the very clean soft rope against the head. this will lock up the engine.
    be very sure the rope is soft and clean.
  8. baddad457
    We have a winner here. This is the most effective, safest way to hold backup on the flywheel. All those prybar methods posted usually end up with something broken or busted (knuckles)
  9. 71gold
    from the sound of this, he has the bolt out (loose)...i don't see why he needs to hold the flywheel...:huh:
  10. justin has a 74
    kentucky
    i just thought the same thing this morning:16suspect
  11. Jsarnold
    Jsarnold Senior Member
    Raleigh, North Carolina
    '72 Sprint
    Tip #1: Remove the center bolt before you try to pull the balancer off. :16suspect :D
    Tip #2: Reinstall the bolt so the puller pushes on the bolt head but don't screw it in so far that the balancer contacts it before it comes free.
    Tip #3: Shouldn't take much force turning the puller bolt to remove the balancer.
