Removing a/c
Discussion in 'Technical' started by 4dr73mav, Jun 1, 2005.
  1. 4dr73mav
    4dr73mav Member
    Weld County Colorado
    1973 4dr Mav V8
    I have a quick question? I have a 1973 302 with a/c. Would removing most of the a/c components allow the car to run cooler?
    I already have the air compressor off because I needed to get to the distributor bolt. The a/c doesn't work and I don't plan on fixing it anytime soon. I only like 3 miles from work so it wouldn't help.
    What all can I remove from the engine compartment?
    Thanks,
    Jonathan
  2. Yellow72Mavrick
    Yellow72Mavrick Banned
    Memphis, Tenn.
    1977 maverick 2 door ( my sons) 250 c4
    ac
    I took entire unit out of my 72, even pulled the ac heater box under dash and striped every thing out but the heater core, took off the lines , evaporator, compressor, all the brackets...everything, you would be amazed at how much that stuff weighs. Now I have loads of room under the hood...power steering is next...Jim(y)
    4door73, not trying to steal your thread but I want to invite you to Toad Suck mini meet on June 25th at Conway Arkansas. Bring your car, family etc...be glad to meet you. check the thread under MCCI meets forum...Jim(y)
  3. 4dr73mav
    4dr73mav Member
    1973 4dr Mav V8
    I would be there if I didn't have to work.:mad: I only get Tuesday's and Wednesday's off. One day my wife and I will make it to a meet. I'm slowly restoring the mav and plan on keeping it for as long as I can.
    Later,
    Jonathan
  4. big_fordsrule
    big_fordsrule Member
    Jackson Oh
    '73 Maverick
    WOW if I only lived closer, I would buy all the brackets and stuff from the a/c. I have a 73 had a 250 in it but now has a 302. I am planning re-installing my ac but will have to get the right brackets and stuff from a V8 car..DARN!!
