rebuilding my 74
Discussion in 'Technical' started by togetic2002, Aug 19, 2007.
  1. togetic2002
    togetic2002 Member
    Reno NV
    72 sprint(major reconsruction),92 5.0 ho t-bird
    because i dont no what happend i was driving about 55 mph when all of asudden it droped to 15 and wont go any faster got home and checked compression and i think it is good all cyl are at 90 psi is that good?:huh:
    no oil in cyl spark plugs good and valves and rings have no leaks it held really good at 90. any ideas? lifters ?rods? timing? help plz if i cant fix it im going to sell it to fix the sprint.
  2. Mavman72
    Could be timing chain jumped.Is it a 6 cyl or 8?could also be fuel delivery.
  3. Mavaholic
    COmpression looks good. If it was running real ruff, I'd say its a timing issue. If it was running about as smooth as before but just slow, I'd say its a fuel problem.
  4. Slantsickness
    Slantsickness Member
    Tucson, Az
    1975 2 Dr.
    Simple things first. Make sure the throttle cable and linkange is ok and check the fuel filter. If it was somthing with the valves, it should show up on the compression test, which sounds like it was ok, so it should be an easier fix. I hope.
  5. togetic2002
    togetic2002 Member
    Reno NV
    k ill start by replacing the pump and send the carb in for a rebuild and wile the carb in the shop ill do the chain:thumbs2:
  6. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    I think what folks are suggesting is that you diagnose the problem.
    They were giving you the order to look at things, not the order in which you should throw money at things.
  7. FoMoDave
    FoMoDave Maverick Owner
    Cumming Ga.
    1973 Maverick 302 c-4,1971 Maverick 6cyl
    I agree with ratio411 . You could replace all those parts and spend even more time and money to find out you got a tank of really bad gas or something. Diagnose the problem first.Could be a bad coil,vacum line,or???.
  8. togetic2002
    togetic2002 Member
    Reno NV
    i pull the coil wire off and found its full of oil? wth:hmmm: never seen this befor ill try that first
  9. Mavman72
    Coil failed.The windings inside the coil are submerged in oil to insulate them from vibration and to dissipate heat.If the oil is leaking out,replace the coil,its done.
  10. newtoford
    newtoford Member
    New Castle Delaware
    new coil will be alot cheaper then doing all that other stuff too lol
