Rear Suspension Upgrade - Engine Bay Missing Some Parts
Discussion in 'General Maverick/Comet' started by Wolf Mcbee, Aug 16, 2015.
  1. Wolf Mcbee
    Wolf Mcbee Member
    1974 Ford Maverick
    Okay so I have been really interested in putting a 8.8 from a mustang that I found close by (literately the house behind me) so I was wondering what would the advantage be and does anyone have one installed? I know the 8.8 is more popular than the 8" but the 9" is where everyone goes but I don't need a 9" also have a leak where the driveshaft and differential connect at the u joint, what's the cause and fix? Also I have parts missing from my engine bay, It was an a/c car but someone tell me what each hole that's covered is for and its purpose thanks
  2. dan gregory
    dan gregory Member
    chesapeake va
    1970 maverick
    Not sure about eng. bay,but the rear end is your pinyon seal leaking.Drop the driveshaft & remove the big nut in the center of the yoke & remove the yoke & replace the seal.
    Wolf Mcbee likes this.
  3. Wolf Mcbee
    Wolf Mcbee Member
    1974 Ford Maverick
    Sweet thanks! I was just looking at the pic too
  4. mercgt73
    The firewall plate is covering up the holes for the evaporator and heater core lines. Hopefully the AC heater box is still behind the dashboard.
  5. Wolf Mcbee
    Wolf Mcbee Member
    1974 Ford Maverick
    Nope everything is gone for the a/c or heater
  6. mercgt73
    I would recommend finding an AC donor car.
  7. Wolf Mcbee
    Wolf Mcbee Member
    1974 Ford Maverick
    I was thinking of ordering from Desert valley auto parts
  8. 71gold
    there is a...crush sleeve...that needs to be replaced at the same time. there is a spec. that it is set to. too tight/loose is big trouble.
    really need to pull the chunk and see if there is any excess wear on the gears from low lube, being it has been leaking.
  9. mav1970
    An 8 inch rear can take a lot of street or track abuse and the 9 is basically for more extreme use or ease of gear selections - why do you feel the need to go to an 8.8?
  10. Krazy Comet
    It's crushed to a specific torque... All the has to be done is mark position relative to pinion shaft(punch a couple dots) and re-tighten nut to that point... Done deal...
  11. 71gold
    would you have that torque spec. for him...:thumbs2:
  12. Mavman72
    The reason round seals go: The bearings on the component that passes through the seal are getting worn out...Causing said component to wobble/drift damaging the seal.
    Other reasons: Dried out/cracked(From old age)...Over heated/cooked...Damage from foregin object.
    You can pull the pinion completely from the housing.It sits in its' own carrier assembly. Look at the bolts surrounding the pinion support,should be 5 of em. Dont loose the shims behind the support cover (Look like steel gaskets) You need to put em back in upon re-assembly. With the pinion/support out of the housing, you can inspect it to a degree. Have new bearings/crush sleeve/seal installed on it and re-assemble. NOTE: this does not guarantee pinion depth will be correct and the diff may be noisey afterwards. Best bet...Just rebuild the diff completely. It will be cheaper than modifying/re-building an 8.8 to put in the car...
  13. Krazy Comet
    Unless there were obvious bearing issues(noisy/howling) or excessive back lash problems, I've never had a issue just poppin' out the old seal, installing a fresh one and retightning to my original mark...
    If the leak is from under the pinion nut, it's almost a sure bet bearings are worn/loose...
  14. Mavman72
    From the looks of where the grease appears to be coming from...I think you nailed it Krazy Comet...
    Looks like its leaking past the pinion nut.
