Rear suspension conversions
Discussion in 'Technical' started by jharrill16, Jul 19, 2013.
  1. jharrill16
    jharrill16 Member
    Appleton Wi
    1972 Mercury Comet
  2. Pony Express
    Pony Express Haul'in @**
    DelMarVa
    1976 Maverick
    I spoke with Rod & Custom no more than three weeks ago with this very same question as they are advertising something similar for models other than Maverick.
    Willie's response was that they tried this, but there wasn't enough room under the Maverick to work with, so they scrapped developing the prototype.
  3. GrabberGT
    GrabberGT Chris
    Fort Worth Texas
    72 Grabber 302
    THeres another build on here somewhere that they cut into the backseat area to mount the upper bars. The upper triangulated bars are just oo long to make this work. Take a look at Topolinos build to see another version using much shorter bars. His kit is from a company in Brazil.
  4. junrai
    junrai Member
    rancho cordova ca
    I would definitely be interested in this product if it works for comets. I am wanting to keep my back seat and still get away from the leaf springs I already have my rear end figured out except the gear ratio.
  5. Cruzin Illusion
    Cruzin Illusion Enigma
    Commerce City, Colorado
    1972 Grabber
    Building and installing 4 link set up's on Jeeps, Topolino's set up does not look right and I honestly probably would not run it. The upper links do not have enough triangulation. It looks like there would be on heck of twisted load on the upper arms as well as the tabs. The arms look to short and at way to much of an angle.
    I usually us a 4 link calculator to help with the proper placement, lengths and angles when building and setting up a suspension.
  6. mav1970
    That might be my build you were thinking of or Sugarkukie's hot pink Maverick which is also done the same way
    And the back seat is still usable:)
  7. GrabberGT
    GrabberGT Chris
    Fort Worth Texas
    72 Grabber 302
    That was on and the other I am thinking about is the Spectre MAv. It started off with a R&C kit I believe.
  8. junrai
    junrai Member
    rancho cordova ca
    now THATS something I can live with. if all you need to do is build a small housing like that count me in!
