Rear spring question
Discussion in 'Technical' started by Fordman2267, Sep 7, 2012.
  1. Fordman2267
    Fordman2267 New Member
    Minnesota
    I just bought a pair of salvage yard E-150 rear springs to transplant in my 71 Maverick. I understand that the bolts are larger on the new springs. My question is, can I buy shackles for the larger bolt size and just drill out the holes on the frame to accommodate the bolts? I want to use the new springs and would prefer not to reuse the original main leaf.
  2. Dave B
    Whats the eye to eye length compared to the Maverick spring?
  3. Joe Dirt
    Eye to eye length is probly alot longer on the van springs
  4. Dave B
    That's what I figured, if you were to get it to bolt up, it would be pretty high in the rear. :Handshake
  5. Fordman2267
    Minnesota
    From what I have found on here, the lengths are almost identical and should work other that the size of the bushing bolt. It was a 6 leaf pack and I removed the 3 smallest leaves.
  6. Mavman72
    What is usually done is this: Spring are taken from the van spring pack, and added to the mavericks existing spring pack. Dont use the vans main leaf...
  7. facelessnumber
    facelessnumber Drew Pittman
    Memphis, TN
    '71 Grabber
    Right. I used the stock Maverick main leaf, although the Econoline leaf is the right length for it. The bushing is the issue. Maybe there is one that will fit but I didn't find it. I used the next two longest leafs from the van spring pack and it ended up just about perfect for me.
