rear shackles
Discussion in 'Parts Interchange' started by ronr11, Apr 2, 2005.
  1. ronr11
    ronr11 Member
    hartsville sc
    71 maverick
    anybody know if mustang and maverick are the same thanks ron
    jc shows a diff part # but they look like they will work
  2. Hawkco
    Hawkco Genuine Car Nut
    Rex, Georgia (GA)
    77 Maverick
    AutoKrafters sells the Maverick shackles.
  3. Yellow72Mavrick
    Yellow72Mavrick Banned
    Memphis, Tenn.
    1977 maverick 2 door ( my sons) 250 c4
    are we talkin stock shackles or the big long nasty ones??
  4. 71gold
    terrys' car has "the big long nasty ones" :yup: :biglaugh: :biglaugh:
  5. ronr11
    ronr11 Member
    hartsville sc
    71 maverick
    shackles
    stock ones has anyone used napa shackles? thanks
  6. Mavaholic
  7. syklops75
    syklops75 Dont touch the spark plug
    suwanee, ga
    1972 4 door maverick
    i know this will sound stupid... but what purpose do shackles serve?
  8. Mavaholic
    As the spring compresses, it gets longer. The shackels are a hinge point to allow them to extend without binding. If the rear of the spring were attached solidly like the front, it would almost be like no springs at all.
  9. syklops75
    suwanee, ga
    ahh.. ok... thanx for the info
  10. gunslinger68
    gunslinger68 Member
    Jackson, WI
    1970 Maverick-347,tr3550,9in,etc.etc.
    What about something like this????
  11. Hawkco
    Rex, Georgia (GA)
    77 Maverick
    Interesting arrangement there, Gunslinger. Give us the pros and cons on that setup.
  12. Mavaholic
    Looks like roller bearings. Much less friction although I would think the rubber would have a dampening effect which I thought would be desireable. Dont know why you would want roller bearings on the leaf springs.
  13. maverick1970
    maverick1970 MCG State Rep
    Missouri
    I have seen a bracket setup like that on a website. Must be in my bookmarks on my other computer. I will look to see if I can find it. Len from Lentech has his on a slide setup like that also, but with some other trick parts to go along with it.
    http://mmb.maverick.to/showthread.php?t=9071&highlight=len
  14. bmcdaniel
    Mav vs Mustang shackles. The metal parts are the same, but the bushings that come with it are different. Mavs use smaller outside diameter bushings.
  15. gunslinger68
    gunslinger68 Member
    Jackson, WI
    They are roller bearings. I got them at a local circle track shop, although I know that Summit sells them now.
    Pro: The idea is to let the spring do what it does freely, the rubber tends to bind, and work against the spring a little bit, I dont know how much the rubber actually effects the spring, but these just eliminate that. I also have aluminum front eye bushings(Global West, internal rotating sleave, greasable). Up and down movement free of bind.
    Con: Noise transfer, road noise, rear end noise, etc. I can't really hear it over the exhaust sound though:rolleyes: .
