rear seat removal
Discussion in 'Technical' started by Jimmy2gates, Jul 10, 2007.
  1. Jimmy2gates
    Jimmy2gates Member
    71 mav
    Hello guys ,got a question, i just removed the front bench seat out of the 69 maverick and started on the back seat ,i lifted the back part of the seat off the two hooks but i cant get the seat part out . Is it bolted through the floor under the rear axle or does it slid out ,im trying to strip the seats and carpet to put sub-frame connectors in and maybe a 6 point cage . help please Jimmy2gates
  2. mavmanerick
    royal city, washington
    on my 72, you push the seat back forcefully and it pops out...
  3. Mavaholic
    You have to remove the lower cushion first. push it rearward and up and it will unhook from the front retainers. Then just pull it out. Then you will see, at the bottom, the 2 bolts that hold the back cushion on.
  4. Jimmy2gates
    Jimmy2gates Member
    71 mav
    Job Is Done
    THANKS GUYS , I MUST TAKE THIS TIME TO SAY THANK YOU TO ALL OF THE MAVERICK FORUM MEMBERS ,MY CAR IS COMMING ALONG SWEET AND ITS ALL BECAUSE OF THE HELP AND KNOWLEDGE OF MEMBERS :cheers: YOU GUYS ROCK
  5. KokopelliMav
    KokopelliMav Member
    Virginia
    1970-1973 Maverick Parts
    OK, So how 'bout the other way?
    So I'm trying to put the rear seat back in. Seems simple enough to reverse the procedure, but it just is not going. Is there some trick to installing the rear seat???
  6. 71gold
    did you run your carpet up around the hooks...:huh:
    ...:bouncy: ...
  7. KokopelliMav
    KokopelliMav Member
    Virginia
  8. 71gold
    look at the ...hook...then look at the bottom of the seat and see how they work. it is a trick the first time :yup:
    ...:bouncy: ...
  9. KokopelliMav
    KokopelliMav Member
    Virginia
    "it is a trick the first time :yup: "
    I just have to figure out the trick!
    The mechanics seem simple enough - I can get the bar on the bottom of the seat under the top part of the hook; I just cannot seem to get the bar to slide far enough back to drop it down in able for it to slide forward under the forward portion of the hook.
    Can't seem to find anything behind the seat stopping it from sliding all the way back either - even removed the back rest to see if that would help (it didn't).
    :hmmm:
