Rear ends
Discussion in 'Parts Interchange' started by Racer_X, Apr 22, 2009.
  1. Racer_X
    Racer_X Maverick Hugger
    North Carolina
    1974 Maverick (1970 clone)
    are there any rear-ends with a 3.00-3.55 gear ratio that will bolt on to a maverick:huh:
  2. rayzorsharp
    You don't need to change out the entire rear end if you have either an 8" or 9" rear end. Just swap out the center section (pumpkin). Most likely you have an 8" in it already.
  3. Racer_X
    North Carolina
    yup its an 8, so i would just need to change the gears then.
  4. rayzorsharp
    You can take out the pumpkin and have the gears changed out to pretty much any ratio you choose but you need to have it done by a professional or you'll likely wind up with a whining noise. The best thing is hit some of the larger swap meets and you can probably find a complete pumpkin with either of those gears setups for $100 or so. I got one a couple years ago for $60, for a 3.50 setup. I see 8" pumpkins all the time at shows with vendors.
    If you have new gears put in yours you'll probably spend $300-$400 including the gears. Still cheaper than changing out the entire rear end.
  5. JD71
    JD71 John Kenney
    mississippi
    71 maverick
    8 and 9 inch centers wont swap between the 2 will they? i can get a 9 inch very cheap but it has drag gears in it, so id like to chage the ratio in my 8 inch until i rebuild my other 302 and then i want to put the 9 inch in with preferably 3.55 gears
  6. rayzorsharp
    No, you would have to change the entire housing.
  7. GrabberGT
    GrabberGT Chris
    Fort Worth Texas
    72 Grabber 302
    Kind of strange seeing your car as someone elses avatar.
  8. rayzorsharp
    :yup: My cars seem to be popping up in several places lately. :huh:
