Rear End Questions
Discussion in 'New Members Forum' started by zman3003, Mar 24, 2012.
  1. zman3003
    zman3003 Member
    1970 maverick
    I found brakes fro granada for the front of my 69.5 maverick and I am now looking for rear end- I belive mine has a 7.5 in it and i am putting a 347 and want to go to a 9 inch...i have a guy with 9 inch t-bird rear ends from 61-67 or 57-59 for 9 inch from fairlanes or lots of pick up 9 inch.....please help so much info out there alot seems to contradict each other.....which of these options would be the best for the car least amount of work? This site is great everyone is so helpful thanks in advance.
  2. mav1970
    I know the 57 to 59 Fairlane 9 inch rears will bolt right in but I'm not sure about any others you mentioned. My 69.5 has a 9 inch rear from a mid 70's Lincoln Versailles (Granada or Monarch are the same) which is also a bolt in plus the Versailles rear also has disc brakes :)
  3. don graham
    Where are you located? 57 Ranchero and 57 wagons are direct bolt ins.:)
  4. zman3003
    zman3003 Member
    1970 maverick
    new york...not sure if they are rancharo or fairlane but they are late 50's ford 9 inch. I wonder if they were the same in the rancharos and fairlanes
  5. zman3003
    zman3003 Member
    1970 maverick
    not rancharo just found out from owner:mad:
  6. jmgford
    jmgford Member
    Iowa
    The T-Bird rears are definately too wide. I believed the only differences in the Ranchero, Wagon (& retractable) rears are the axle bearing size & bigger brakes. Any '57-'59 full-size Ford rear will bolt in.
  7. mav1970
    I know the Ford pick up trucks, that I have seen, are big time too wide. Some early Broncos may fit but they have different offsets as to where the yoke is due to the 4x4 configuation :)
