Rear end questions
Discussion in 'General Maverick/Comet' started by 4-SPEED, Dec 31, 2008.
  1. 4-SPEED
    4-SPEED Member
    Tucson AZ
    I sold a kid a 9 inch for his 72 Comet ....it has an 8 inch now ....Does it require a new drive shaft ???? Or can he use the stocker ???? I never had this issue .....so I had to ask ... Dont want to sell something he cant use since it took him a month to get the money !!! Thanks
  2. 72mercGT
    72mercGT New Member
    Medina Ohio
    72 Comet GT & 72 Montego GT
    Should be fine as is. The only question would be the yoke size on the 9"
  3. 4-SPEED
    4-SPEED Member
    Tucson AZ
    The yoke
    It looks the same and the u-joint even fits the yolk out of a stocker in my yard !!! Try it and see I guess !!!
  4. 72mercGT
    72mercGT New Member
    Medina Ohio
    Should be no problems then.....
  5. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    9 inch rears used at least 2 different u-joint sizes. Sounds like you have the same size as the 8". However if it does take a different u-joint, all you have to do is get a hybrid joint. They are sold right at Advance or whatever corner parts house you have in your area. 2 bearings will fit into the Maverick driveshaft yoke, and the other 2 will be the size that fits the 9" yoke. Common part.
    So no matter what, no problem.
    Driveshaft length won't be affected.
