rear end opinions
Discussion in 'Drag Racing' started by RobbieG., May 16, 2012.
  1. RobbieG.
    RobbieG. Member
    Phoenix Az.
    75 Maverick, 72 Maverick sprint, 67 Mustang bracket car, 02 F250 4X4
    Tell me what you guys think.My car makes just over 400 HP.
    Full spool VS Mini spool? Is a full spool over doing it?
    Who makes the best axles?
    I want to rebuild it right?
  2. maverick1970
    maverick1970 MCG State Rep
    Missouri
    I would overbuild it, since your racing it, full spool and good axles. I would stick to companies like Strange or Mark Williams.
  3. fordman57
    fordman57 Member
    Hinton WV
    71 Comet
    rear end
    Strange has deal on 35 spline axles and spool. I am building fox body
    drag car for guy now, got a good deal should last a long time
  4. MikeG747
    MikeG747 Member
    Arkansas
    I agree with Strange. I also agree with overbuild. Go with 35 spline! Good luck. (y)
  5. Bizzness
    Bizzness Member
    71 grabber 351w, c6 ,9" 4.56 locker, subframe, roll cage
    I have 39 spline. The guy that helped me put my car together said to go overboard on the rear so if u ever wanted to make more power ur already ready for it in the rear.
  6. Bryant
    good way to go. except the 35 spline spool wont fit in a standard case. you need 3.25 bore case. to fit the 35 spline spool. there are 35 spline spools that will fit but they are too thin on the bearing journal and will brake.
  7. don graham
    I know a lot don't like Moser but I've been running a 9" with Moser 33 spline axles and Moser full spool with 4:33 gears for over 10 years now with no problems.:)
  8. ShadowMaster
    ShadowMaster The Bad Guy
    The ShadowLands
    1969 1/2 Maverick
    Really? You sure about that? :rofl2:
    Moser or Strange or Mark Williams. 31 spline will be more than adequate for your application. Just be sure to buy the spool and axles from the same manufacturer. They won't interchange between companies.
  9. Boss302maverick
    Boss302maverick Member
    New Jersey
    1971 maverick grabber
    Actally they WILL interchange, all the 31, 35 spine stuff fits everyone elses stuff, you can use mosier,strange,mark williams axles with a ford locker, posi, or anyone elses stuff.
  10. Bizzness
    Bizzness Member
    Yep my rear end was made out of a f-450s rear end. It all rated for 1200 hp. Any other questions? U should see my u-bolts I had to weld a plate on my traction bars to make them work
  11. Joe Dirt
    So you got a 1.5 ton full floater rear end in your car?
  12. blugene
    I want to see a pic only cause I like seeing different stuff being used in our cars..
  13. Bizzness
    Bizzness Member
    The people that made it said the housing was a f-450s. They shortend it to fit my car. Then the guy that built my engine put the the rest of the stuff in it. And he says it's 39 spline and has a Detroit locker and the rest is Yukon stuff that's rated for 1200 hp that's about all I know. Oh and it has 00 explorer disc brakes. And it wasn't cheap
  14. Bizzness
    Bizzness Member
    Look at my pics
  15. Joe Dirt
    You really dont know what you have thats a 9" it maybe out of a F150 or a F100 and it wont take 1200 hp without some serious work to the housing.
    You cant get a detroit locker with anything over 35 spline also
    A F450 is a ton and a half truck and uses a huge rear end that has full floating axles
