Rear end ID
Discussion in 'Technical' started by rmmpe, May 12, 2009.
  1. rmmpe
    rmmpe Member
    Milford, PA
    1933 REO Roadster
    The tag on my differential carries the numbers:
    R-F- 9JB
    7587 0004A
    Can anybody decipher the numbers for me?
    Thank you very much.
    Bob
    Milford, PA
  2. rmmpe
    rmmpe Member
    Milford, PA
    1933 REO Roadster
    Just a bump because I still need the info.
    Thanks.
    Bob
  3. rthomas771
  4. Acornridgeman
    Wisconsin
    Hi Bob, that doesn't sound right to me either. :huh:
    The 9JB looks like a build date - 9th year - 9th month - 2nd week
    (1969 ? - September - 2nd week)
    Here is a rear tag from a 68 Cougar - 1967 - December - 3rd week
  5. rmmpe
    rmmpe Member
    Milford, PA
    1933 REO Roadster
    OK, OK.
    Now you've done it.
    From all I've seen, the numbers don't make a lot of sense.
    I guess I'll have to get down and get the numbers myself.
    And.....the REAL numbers are:
    WER-F 9JB
    2.75 87 0004A
    The tag was buggered and had to be removed and straightened a bit.
    From the info posted on the site Jeff gave, the following is gleaned:
    [FONT=Verdana, Arial, Helvetica, sans-serif]WER-F [/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]Ford Pass. '67-'74[/FONT]
    [FONT=Verdana, Arial, Helvetica, sans-serif]Mercury '71-'73 - [/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]2.75 ratio, [/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]8 3/4 in, [/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]Non Locking, [/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]28 spline, [/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]Non-Removable Carrier[/FONT]
    The 2.75:1 ratio explains why I see 2,000 RPM at 60 MPH. Also why it's a bit "Doggy" off the line (but it cruises quite well for an almost 80 year-old car).
    Supposedly, the entire frame, suspension and driveline came out of a Torino (seems someone raised the 1933 REO body and drove another entire assembly under it). There is no engine tag and noone has been able to positively identify the 302 and "Cruise-o-matic" C4.
    Getting closer but still no Chohiba (sorry Bill), I'm still trying to get more information as to what year the goodies were built. However, from what Eric provided, the 2nd week of September 1969 is probably what I needed.
    The reason I'm looking for the info is some genius pulled the studs from the front rotors and replaced them with racing studs they tack-welded into place. When being inspected and the front wheels removed, it was discovered the tack-welds had broken loose and the studs fell out. The rotors must be replaced before the car will pass the safety inspection. The big questions is, what rotors are required?
    Your information has helped there and I thank you for it.
    For those of you wondering why I decided to go the regular registration route rather than the "Antique" route; PA has buggered the process and it will take some 8 to 10 weeks for some no-name government worker to "Approve" the title. Consequently, the remaining nice weather would be somewhat limited, which is important when dealing with a Roadster.
    Again, thanks guys. Your help is greatly appreciated.
  6. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    Best bet would be take one of the rotors to a good parts store and compare it to known Torino or Mustang or Maverick parts.... Factory parts should have a number embrossed in them somewhere, but if they were aftermarket replacements they might not.
  7. rmmpe
    rmmpe Member
    Milford, PA
    1933 REO Roadster
    That's a good idea and we tried it. Unfortunately, the rotors are so far out of print there were none available to compare them against.
    They were ordered against the dimensions and dates of fitment (also supported by the info above). They are quite thick and there were only two (2) 11" possibilities (Torino/full size and Thunderbird) and hopefully the rotors ordered will fit properly. I'll know tomorrow.
    If they don't fit, I'll take them back home and machine the backs flat again so we can re-install the proper studs.
    I suppose a lot depends on the "Luck Genie".
    More to follow.
  8. Acornridgeman
    Wisconsin
    Here is a shot - get me the wheel bearing numbers and I can reverse look up what rotors they fit.
    just an idea ....... :idea:
  9. rmmpe
    rmmpe Member
    Milford, PA
    1933 REO Roadster
    Another good idea.
    If I have trouble with what has been ordered, I'll get those numbers.
    Thanks.
    PS, I lived in Stoughton for 5 years. Short but beautiful summers.
  10. rmmpe
    rmmpe Member
    Milford, PA
    1933 REO Roadster
    The rotors ordered fit just fine and the REO is now legal. Happily, I'm done with this for a while (until I get the bug to do something else).:bananaman
    Thanks to all of you that offered help with this. :clap:
    It was required and greatly appreciated. :tiphat:
    Bob
