Rear disc brakes
Discussion in 'Technical' started by maverick306, Dec 6, 2016.
  1. maverick306
    maverick306 Member
    Kinston NC 28501
    1974 ford maverick
    Has anyone used wilwood brakes on a Maverick we put a 8.8 rear end and put brakes on change the master cylinder one for front disc brakes but the rear brakes want to stay locked up doesn't want the Roll free any suggestions
  2. 71maverick361
    71maverick361 Vern Isaac
    Odem
    71 Grabber
    Proportion valve ? Lines in good codition ?
  3. 71maverick361
    Odem
    71 Grabber
    Your sure brake is locked and not the rear end having a issue ?
  4. Maverocket
    Maverocket Bob Williams
    Northwest
    69.5 Mav, 62 F100 unibody
    If you have a disc/drum master cylinder there may be a residual pressure valve on the rear line.
  5. maverick306
    maverick306 Member
    Kinston NC 28501
    1974 ford maverick
    Everything is brand new thinking it's just tight to the hand turning it. We will find out more when we can crank the car and running. Thanks for all the replies
  6. 71gold
    if the rotor turned free and it's just tight to turning by hand with calipers and pads installed, it should be fine...:thumbs2:
