rear brake lines
Discussion in 'Technical' started by Racer_X, Dec 17, 2012.
  1. Racer_X
    Racer_X Maverick Hugger
    North Carolina
    1974 Maverick (1970 clone)
  2. rthomas771
    I doubt it's a direct swap. The Mustang is wider and longer than a Maverick. Also a Mustang is a Mustang…not a Maverick
  3. 71gold
    I would say yes...
    Craig knows a company that makes these new for a Maverick.
    ...:drive:...
  4. Dave B
    Right Stuff Detailing makes them for Mavericks.
  5. Racer_X
    North Carolina
    being that its just the axle section i need woulndt it work anyway? if its made for an 8inch axle it should work right?
  6. Craig Selvey
    Dave beat me too it.
    www.RightStuffDetailing.com
  7. Dave B
    Might be a little long, since Mustangs used a wider rearend, but with enough bending, anything is possible...then you may as well just make your own. If you have the tools...
  8. MSmithPDX
    MSmithPDX Member
    Portland, OR
    Might just be me. but that link doesnt work.
  9. Acornridgeman
    Wisconsin
    If you can make your own, that will be the easiest and cheapest.
    As for Right Stuff, they are a great company to work with but their web site severly lacks postings for all the things they make, including their line of Maverick parts. Anyone that needs lines from them, best to just call and tell them what you need. They can make it all.
  10. Racer_X
    North Carolina
  11. rthomas771
    Why spend $50 for 25 feet of tubing when you only need 5 or 6 feet? You can buy pre-made sections of brake lines from any parts store for around $15 and it will come already flared and with new fittings installed.
  12. 74LDO
    74LDO Member
    Ohio
    1974 Maverick LDO
    brake lines
    I love to bend lines part of my trade But Right Stuff makes the best fitting lines out there and they have all the wire wrap in the right places. I have used Fine Lines as well there stuff is very competive to Right Stuff's. The brake line you show from jeggs is available at your local parts store for much less. The last roll I bought was about 16.00. The thing I found out about the new tube is it doesnt unbend very well, if you ever tried to fix up a bend thats not quite right you enbend one side and start the bend sooner on the other side....I vote for Fine Lines and a job well done!
  13. 71gold
    2nd. that...you will need 2 pieces...:thumbs2:
  14. Craig Selvey
    Opps.....link fixed.
  15. predfan2001
    I've measured rear brake lines with a tape measure (actual soft tape measure like for sewing) and then picked up a line from NAPA in the length I needed. A simple hand held bending tool is only a few bucks at AZ or HF.
    The next step up
