rear axle size question
Discussion in 'Technical' started by j miller, Jun 13, 2005.
  1. j miller
    Polson, Mt
    yesterday i went to swap tires from my 71 mav with a 8"rear to my wifes 77 mav and the center hole on the 77 is slightly larger than on my 71. what gives? :huh: does this mean that she has a different rear in hers? how do you tell what rear end is in what car? only by the vin or is there some way to look at them and tell? i thought all 8"rears had the same size center hole for the wheel. :huh: any help would be nice.
  2. blugene
    Wish I knew, I had trouble getting a drum one time.
  3. RegL404
    RegL404 Member
    starting in 73 or 74 they went to a bigger center on the axles
  4. Grabber75
    Grabber75 Member
    Mount Vernon, Ohio
    1975 Maverick Grabber
    Thats right.....when they changed to disc brakes on the front the hub was larger so they changed the rear axle size too to match the center hole for the wheels.
