Quick transmission question
Discussion in 'Technical' started by Alexdvs, Nov 18, 2014.
  1. Alexdvs
    Alexdvs Member
    South Jersey
    1977 ford maverick 4 door
    My transmission in my 77 maverick is going bad and I'm in the market to get a new one. I found a transmission out of a 70' maverick with a 170ci engine, I wanted to know if it would fit properly onto my 77' 250ci engine?
  2. Mavit
    Mavit Member
    Prince george bc
    two muatangs ansd one comet
    You don't say if it is standard or Auto if it is standard the bell will unbolt and they can be interchangeable If the bell is the same depth ! With the Auto there were different styles of converter used on the 6 engines and the one for the 170 may not match the depth of your 250 ! The 170 and 250 do not have the same bolt pattern so the bell has to be changed to match your engine!
  3. Alexdvs
    Alexdvs Member
    South Jersey
    Im sorry I completely forgot to mention that the trans is auto. So your saying in order for it to fit on my 250 i would need to get a bell matching that of the 170?
  4. 71gold
    the 250 and 302 had a better built transmission than the 170-200.
    Acornridgeman likes this.
  5. Krazy Comet
    Has that ever been proven?? The 1969 price list for Mustang lists the 6cyl auto for 200 & 250 at same price, while the one for 302 & 351 were approx $10 higher...
    As far as a '70 trans working, the 250 bell and converter would have to be swapped to the 170 trans, that I'd think was lighter duty than one for a 250...
  6. 71gold
  7. rthomas771
    I heard the 250-302 C4 has one more clutch than the 170-200 C4. The extra clutch requires a deeper drum.
  8. Acornridgeman
    Wisconsin
    I took a look at the shop manual to see if I could find out something useful for this thread. It does not break down the C4's by application (engine size) - just by the tag code.
    The 170 had the lowest RPM torque converter.
    As for the transmission itself, PEB and PEG (the semi-auto included here) have 1 less clutch plate, different servos, different shift points. I would assume all designed for the weaker engines.
    The PEA - PEE - PEF were the C4's made for more powerful engines.
    And you can't lump the 170 /200 together all the time on this one. I had a PEE on my 1972 200.
    Another Ford thing I guess.
    :cool:
  9. Acornridgeman
    Wisconsin
  10. Mavit
    Mavit Member
    Prince george bc
    There is no question about the fact that a 250 and 302 use a different C4 than a 170 or 200 but it is also a fact that you
    can use a 170 tranny behind a 250 and not have a problem! I bought a 1982 mustang with a 200 6 with a C5 , I replaced the engine with a 302 and a high stall converter and a C4 valve body with a shift kit! I run that tranny for 2 seasons
    with no problems, That tranny had 3 frictions in one clutch and 4 in the other ! The car run 13.2 at 103 mph, If a stock 6 cylinder box will handle that you could go a long way under normal driving with out a problem!
  11. Krazy Comet
    Thanks for the links, appears the 250 & 302 C4 do have similar internals...
    My '71 GT parts car with 200 has a PEB-H... Dunno about '72 never looked at it, though I know Brian put it back in place after the rebuild...
  12. Acornridgeman
    Wisconsin
    :xmas:
    According to the chart, the 200 Maverick in 1972 has a PEB.
    My car is a Dearborn car, and they may have just used what they had at the time. According to the charts they did use PEE with a 200 in the Fairlane and Torino.
