Quick question...Does serpentine setup water pump spin clockwise or counter?
Discussion in 'General Maverick/Comet' started by scooper77515, Nov 10, 2013.
  1. scooper77515
    Water pump is leaking. May as well use this opportunity to buy a new high volume pump.
    Just need to know what direction is spins so I know which one to buy. :huh:
  2. Jsarnold
    Jsarnold Senior Member
    Raleigh, North Carolina
    '72 Sprint
    If your current water pump pulley is smooth, its a reverse rotation. If its ribbed, its a standard rotation.
  3. scooper77515
    But is standard clock or counterclock?
    Mine is smooth.
  4. blugene
    Back when I worked at Pep Boys I would match the blades to make sure when there were doubts or questions. Usually a couple or 4 bolts to remove the back plate. Then I could apply some tack sealer..
  5. Jsarnold
    '72 Sprint
    I know some parts places list the pumps as clockwise or counter-clockwise. I was never sure if that meant the rotation when facing the back of the car or the front. :huh:
  6. blugene
    Faceing the engine..
  7. Jsarnold
    '72 Sprint
    Standard rotation is clockwise when facing the engine..
  8. blugene
    Correct. But when someone has changed their pulleys and stuff they could have changed something to create a reverse flow especially when dealing with a serpentine style.
  9. scooper77515
    OK, so when the one I have in the cart says Counterclockwise, it should be the one I need.
    Thanks a bunch!
  10. 71gold
    when I changed mine over to the serpentine system, I routed the belt to turn the water pump the same way the v-belt turned it...:yup:
  11. scooper77515
    And what did that do for your cooling system?
    I assume that was for the chevy engine, and it needed to spin that way anyway?
  12. 71gold
    it was on my... 72-302
  13. Krazy Comet
    AFAIK you can't mix up the pumps, the CCW pumps have a wider bolt pattern...
