Quick Carb Question
Discussion in 'General Maverick/Comet' started by 71COMETGUY, Dec 13, 2016.
  1. 71COMETGUY
    71COMETGUY Member
    Los angeles
    71 comet
    So ive noticed around the internet that people have the same car as me (71 comet inline 250) STOCK but some things arn't the same in the engine. Such as carburators/air filters/pcv,vacume locations. Could this be because im in California or because not all of them are the same? 20161213_075348.jpg 20161213_075526.jpg
  2. 71Mavrk
    71Mavrk Member
    Nevada
    I have never seen the PCV line split. Where does the other end connect to?
    Micah
    (Former 170 owner)
  3. 71gold
    You're in California and not all of them are the same...:bouncy:
    the port on the T-stat housing has vac. after the engine warms to operating temp.
  4. dyent
    dyent Member
    vancouver bc
    3 port Ported Vacuum Switch (Distributor Vacuum Control Valve) for emission control, top to carburetor, middle to distributor and bottom to intake manifold, is what that assembly is on top of Thermo housing is called.
    - EGR/CSC switches EGR vacuum from EGR system to distributor advance with cold engine.
    - Cold Start Spark Advance (CSSA) supplies manifold vacuum to distributor below 125 deg. coolant temp.
    - Coolant Spark Control (CSC) cuts off distributor advance below hot engine temp.
    - Cooling PVS switches advance vacuum from spark port to manifold vacuum if engine overheats.
    David
  5. 71COMETGUY
    71COMETGUY Member
    Los angeles
    71 comet
    Brake booster and pcv. I do t see where else i could connect them
  6. 71COMETGUY
    71COMETGUY Member
    Los angeles
    71 comet
  7. 71COMETGUY
    71COMETGUY Member
    Los angeles
    71 comet
    Th
    Wow lot to take in but thanks
  8. mvw66gt
    mvw66gt Member
    Arthurdale, West Virginia
    71 Comet GT
    I, sure someone else will mention it, but I don't think the brake booster vacuum should be hooked to the PCV. It should be hooked directly to the manifold vacuum source. - Matt
  9. 71COMETGUY
    71COMETGUY Member
    Los angeles
    71 comet
    Its splited so the pcv stuff doesnt go into booster. But it seems to work fine
