Question on Weight!
Discussion in 'Technical' started by EZDUZIT, Sep 17, 2009.
  1. EZDUZIT
    EZDUZIT Member
    Spartanburg S.C.
    1972 Ford Maverick Grabber
    I'm just goofing off here and was wondering how much a 1972 Maverick 2 door weighs? I mean on a scale not GVW. I was playing around with the power to weight ratios! If I could down to 5.8:1 I could run with a Hayabusa!:yup:
  2. Mavaholic
    My 72 Sprint with aluminum heads, intake & radiator, 4 speed, 9", steel wheels, and a full tank of gas hit 3040 lbs on a certified CAT scale.
  3. PaulS
    Depending on the model, the interior package and other options the weight will be between 3000 and 3200 pounds (curb weight) add to that your weight and then divide by the ratio you want - that will give you the HP needed to get the performance.
    5.8 pounds per pound is not very realistic for a street car - you will need up to 550 HP.
    Not to say it can't be done - just that it would be a bit extreme for a street machine.
  4. Bryant
    it built this car for a customer. http://www.allfordmustangs.com/Detailed/157.shtml
    one night he calls me up and tells me how he pulled away from a hayabusa on the freeway. the guy on the bike could not belive that a convertable beat him. its doable but expensive.
