Question on shorter front bumper
Discussion in 'New Members Forum' started by NorCalComet, Oct 4, 2011.
  1. NorCalComet
    NorCalComet New Member
    Livermore, California
    1973 Mercury Comet
    Hello,
    I have a 1973 Comet, and it has the huge front bumper. I have been looking at pictures and i see that some comets/mavericks have a shorter (not as grandma looking) bumper. Is there an internet site that sells the bumper conversion kit with directions?
    Thanks,
    NorCalComet
  2. yellow75
    Tillamook Oregon
    Nope :cry:, everybody that has done it has had to buy used parts or modify what they have
  3. NorCalComet
    1973 Mercury Comet
    Okay thanks. Did Mercury make Comets with a shorter front bumper?
  4. yellow75
    Tillamook Oregon
    Yes 71 and 72
  5. mercgt73
    Just to defend the 73's, they did not get the LARGEST front bumper. '73 is actually a 1 year only bumper. If you do the swap, don't junk the original bumper, someone could probably use it.
    Check this out: http://mmb.maverick.to/showthread.php?t=44352
  6. yellow75
    Tillamook Oregon
    Same with the front valance
  7. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    I saw them in autokrafters for $375 with no core. Not sure how true that is.
  8. mav1970
    :Welcome: to the forum from Northeast Pennsylvania
  9. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    Do a search for 'bumper slide'. You might like the look, and you won't have to spend the cash to do a swap. There are several things needed to swap to the difficult to find '71-'72 Comet bumper. Mounting, fender notching, front pan is different, plus that bumper is unique to '71 and '72 Comets. From '73 on the front bumpers for Comet and Mavericks were the same.
  10. Streetdeacon
    Streetdeacon Streetdeacon
    Bellingham, WA
    1977 Maverick 2dr.
    You might be surprised at the difference just moving the bumper in 2 or 3 inches will make in the appearance of you car. You can check out my images. I did a 3 inch tuck in the front and a 1 1/2 inch in the rear. :tiphat:
  11. socalcomet
    socalcomet Member
    Menifee, California
    1974 Comet
  12. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    :Welcome:to the site!!!!!
  13. Mercurycruizers
    Venetia, PA
    :Welcome:to the board.... I have a 73 Comet also. I did the bumper tuck. I like the semi big bumper compared to the thin one. So, I sucked mine in. Gives it a better look. Good luck!!!
  14. NorCalComet
    1973 Mercury Comet
    How does one go about switching the bigger bumper for the smaller bumper? Is there alot of modafication that needs to be done, or is it a fairly simple job?
    Thanks,
    NorCalComet
  15. NorCalComet
    1973 Mercury Comet
    I like the whole "tuck" idea. How would i go about doing that?
    Thanks,
    NorCalComet
