Question about 289 heads...
Discussion in 'Technical' started by T.L., Jul 8, 2005.
  1. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    Can anyone tell me what the combustion chamber size is on 1966 289 heads?...
  2. rayzorsharp
    I'm probably wrong but I seem to remember the 2V heads at about 58cc. I'm sure someone on here will have the correct info for you.
  3. Dan Starnes
    Dan Starnes Original owner
    West Central IL
  4. Dan Starnes
    West Central IL
    RE: is this a hipo manifold
    by john 4/15/2001, IP 216.68.15.90the valves on the 302 4v heads are the same size as the 2v heads in 68. the only difference is the combustion chamber size. 53-55cc vs. the regular run of the mill 2v heads at 63-66cc. the smaller chamber bumped advertised compression to 10.5 to 1. the heads are clearly marked with a 4-V cast into the head on the top side. yes, they will wake up a 2v 289/302 rather nicely.
    The above reply is what I have always thought to be correct. And is the rule I have always gone by.
    Dan
  5. RegL404
    RegL404 Member
    1966 should be 54ish.
  6. T.L.
    T.L. Banned
    Southern Colorado
    These are 2V heads, sorry I forgot to mention that little detail...
  7. T.L.
    T.L. Banned
    Southern Colorado
    I have always heard (and even read) that '68-'76 302 heads are 58-60cc chambers (2V).
    I was just wondering how much smaller (if any) the '66 289 2V chambers were, and how much they'd bump the compression on a 302 from 8:1 with the stock dished pistons.
    I have 2 sets of these heads. I already know that aftermarket heads will out-flow them. My question right now is strictly concerning compression ratio...
  8. RegL404
    RegL404 Member
    around 8.35 all else being egual with a reduction of 4ccs
  9. T.L.
    T.L. Banned
    Southern Colorado
    Thanks for all the replys..
  10. ghenry36
    ghenry36 New Member
    Selah, Washington
    1973 Maverick
    If you have not found out what size they are, you can try using alcohol and a hyperdermic needle and measure how much fluid they hold before the overflow.
  11. maverikrick
    maverikrick Member
    Nogales, AZ
    '74 2dr LDO V8 project
    All at 54.5
    Here is a table that shows all 66's at 54.5. I had previously read differences in CR in 66 were done with pistons. http://home1.gte.net/res03net/faqs/head.htm
    Don't know how accurate this is but it lists everything by casting number, with valve sizes, including 302's.
  12. T.L.
    T.L. Banned
    Southern Colorado
    Thanks. That's a very informative site...
  13. T.L.
    T.L. Banned
    Southern Colorado
    Although I did discover that the information for intake valve size was wrong. The '65 and later 289 heads all had the same size valves as the 302 heads. It was the early ones that had the smaller intake valves...
  14. maverikrick
    maverikrick Member
    Nogales, AZ
  15. Earl Branham
    Lugoff, SC
    T.L. I have a set of these, '66 289 4v heads, and I have heard everything from 49cc to 64cc. Don't really know which is which. I think I am going to port these out and use them, but just don't know when. Thinking it might be easier to get a set of late model heads, and get the same results, just cheaper. Good luck!
