Putting a fox body 302 in my Maverick. What headers should I use?
Discussion in 'Technical' started by 75Mav91Stang, Jun 6, 2007.
  1. 75Mav91Stang
    75Mav91Stang Member
    Essex Fells, NJ
    1970 and 1975 Ford Maverick
    As the title says I'm putting a 90 5.0 in my Maverick. Which headers should I use? I was looking at the Mac Long Tubes with 3in collectors. Any one have any opinions? My Maverick is a c-4 automatic with a column shift. Thanks in advance :)
  2. rayzorsharp
  3. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    Do a Search on Column shifter headers .... it will take some modifications to get your setup to work. Hooker 6901 is the only way to go ..
  4. rayzorsharp
    Oh yeah...I didn't notice the column shift. Thanks Dan
  5. 75Mav91Stang
    75Mav91Stang Member
    Essex Fells, NJ
    What modifications will I have to do to make the hookers fit?
  6. dmhines
    Cumming, GA
    Not to be rude ... but I already said do a search and you will find the info ..
  7. 75Mav91Stang
    75Mav91Stang Member
    Essex Fells, NJ
    You're not being rude, its fine. I did do a search for the column shifters, maybe I was looking in the wrong place, but I couldn't find anything
  8. rayzorsharp
  9. 75Mav91Stang
    75Mav91Stang Member
    Essex Fells, NJ
    Alright that helps some so thank you. Since it is a fox body (1990) 302 there are a few things that are different though so
  10. newtoford
    newtoford Member
    New Castle Delaware
    a 302 is a 302, the'll all go in the same way and header fit will be the same. run a few searches "302 swap" "Headers" "floor shift conversion" theres alot of info on here already.
    good luck
  11. mavtricks71
    mavtricks71 Member
    A Fox For A Fox :)
  12. dmhines
    Cumming, GA
    If you are talking about converting it to carburation ... well that's an entirley different bag of worms ... :) but easily done ...
  13. shaunh82
    shaunh82 Member
    Washington NJ
    71 Pinto sportsroof
    the thorleys are nice, have a set on my car, but I've got a t5 in mine
  14. 75Mav91Stang
    75Mav91Stang Member
    Essex Fells, NJ
    Yes, I will be turning that into a carbed 302
  15. 75Mav91Stang
    75Mav91Stang Member
    Essex Fells, NJ
    You should come over and help me do the swap :)
