Pushrod length?
Discussion in 'Technical' started by ShelbyMaverik74, Nov 3, 2009.
  1. ShelbyMaverik74
    ShelbyMaverik74 Member
    Enon, OH
    1974 Shelby Mav Clone
    Well Im about to put my 86 302 roller together with my AFR 185s and heard about checking the pushrod length. How? I have seen push rod length checkers for chevy's but not Ford. My combo is as above with , Ford Racing x-303 cam, push rods, roller lifters, and aluminum roller rocker. All FR. THe instructions that came with my heads say get a lunati pushrod checker but the lunati one says chevy.
    What gives, do you not need to check this with ford, is the blue oval infallable, I would like to hope so but putt too much money into this stuff. to trust that. Maybe I will just call Ohio George and ask him to finish the assembly for me. He did the short block.
    Any help from you master engine builders would be great, thanks.
    Aloha
  2. Blown 5.0
    MS.
    1974 Maverick
  3. ShelbyMaverik74
    Enon, OH
    Roller
    It is a roller motor with regular style roller lifters.
  4. Blown 5.0
    MS.
    1974 Maverick
    Sorry i edited my post while your were typing, Been a long day.
  5. ShelbyMaverik74
    Enon, OH
    Thanks
    I just ordered the Trick flow checker and some moly lube. looks like i have work to do.
    thanks again
  6. scooper77515
    I just slapped mine together with the stock pushrods, and found that there was slop in the exhaust, and measured how much slop was there.
    I ended up buying a set of lash caps to fill in the blanks.
    Not sure if that will work for you, but this $16 fix DID work for me.
    My exhaust lobes had a smaller base-radius (or something along those lines).
  7. Bryant
    quick question. are you useing the 86 pistons?
  8. scooper77515
    what's wrong with 86 pistons?
    I ask because mine was rebuilt with flat-top pistons with 4 valve reliefs. I hope it doesn't crash my motor....
  9. mean_maverick
    factory '86 pistons are completely flat with no reliefs..... could cause damage with those heads
  10. Bryant
    thats what i was geting at. the cam being used is big. the heads have biger valves. im pretty sure that the stock 86 pistons wont clear the valves.
  11. scooper77515
    Hmmm...good question.
    The guy putting the engine together should be checking this kind of stuff out.
    I mean, who slaps heads on a block and starts the engine up without first rolling it over by hand ,measuring the clearances?
  12. Bryant
    every person who doesnt know better, and that isnt a member of this great board full of knowlageable people the happy help the people who dont know.
  13. ShelbyMaverik74
    Enon, OH
    no no no fellas
    I didnt spend 1500 dollars on a set of shiny heads to trash em up. I have speed pro forged pistons with butterfly reliefs. I am gonna check em with clay anyways because the AFRs valves have a slight twist to them and my valve reliefs are pretty much straight across. My bottom end however is stock reconditioned. the pushrods arent the factory pieces they are a ford racing specific part. now I don't know if that makes them any different, but i will be finding out this weekend if its all going to work.
    right now i have to get back to my engine bay clean up, i found a rust hole under my battery and well i think the battery is gonna have to go in the trunk.
    thanks for all the help.
  14. Bryant
    all right. good to hear. just looking out for a fellow mavricker. keep us updated on the progress and take lots of pics.
  15. bmcdaniel
    I have Speed Pro forged pistons in mine and had to enlarge, radially, the valve reliefs to clear the 2.02/1.6 valves. Cam duration will have a big affect on your clearance.
