Pulley Sizes?
Discussion in 'Technical' started by 71 Comet, Aug 14, 2007.
  1. 71 Comet
    71 Comet Member
    London Ontario Canada
    1971 Comet
    On my 1971 302 it has a single groove pulley set up. the crank pulley is 6 3/4" diameter and the water pump pulley is 7" diameter. I want to put a double groove crank pulley on. My question is should the double groove crank pulley be the same diameter or do I need to buy a set of pulleys (crank and water pump)? I have an 8" double groove pulley but it won't fit because it hits the water pump pulley, so if I switch to a smaller water pump pulley I will be speeding up the water pump speed considerably.
  2. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    If you are comparing stock pulleys, the multi-groove crank pulley uses a different (smaller) WP pulley.
    Yes, it does speed up the WP and probably has increased parasitic losses because of that. Probably speeds up the WP because multi-grooves were used on cars with alot of accessories like A/C and such. My guess is they engineered it that way because the accessories would make the engine run hotter.
  3. 71 Comet
    71 Comet Member
    1971 Comet
    Thanks for the info. Paul
