Pro comp ignition kit ?
Discussion in 'General Maverick/Comet' started by strokermaverick, Oct 14, 2010.
  1. strokermaverick
    strokermaverick Member
  2. maverick75
    If its pro comp from australia then they get their stuff from china. A simple google search and youll see how crappy their products are. Why not run a factory duraspark system? Its more than enough for a street/strip car. Distributor and ignition box at junkyard 25, another 25 for a new coil,cap/rotor, o ring..... It ends up being 50 bucks for one of the best ignition setups for our cars. Or you can run one of MSD boxes for under 150, which is still less than the pro comp stuff.
  3. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Run as fast and as far away from that stuff as you can.....
  4. darren
    I only bought one pro comp product. A fuel regulator. It worked for about 90 minutes then left me stuck with 1 psi fuel pressure. Hit it with screwdriver and it jumps back to 5 psi. hit it again and get 1 psi. What a piece of junk. Never again will I buy anything pro comp. Cheap Chinese crap.
  5. JHodges
    JHodges thumper
    Dora Alabama
    I have heard those distributors are junk. There have been several instances of them coming apart
  6. idrivemav
    idrivemav Member
    texas
    1975 maverick
    im running pro comp heads wich are not made in china and i have had nothing 2 complain about but i have heard that there ignition products are junk
  7. mav1970
    The only thing Pro-Comp, that I am running on my Cleveland, is an aluminum water pump.
    I was aiming towards their ignition at first but, reading all of the negative feedback, I waited until I could afford MSD and bought my distributer and 6A box from them instead.
  8. strokermaverick
    It is settled, no procomp ignition for me. I have thought about, if the voltage output would be what it is supposed to be, and if there would be any quality to it. Just wishful thinking on my part. Thanks for chiming in guys.
  9. drag460
    drag460 T-Shirt guy
    El Paso, TX
    China rip-offs! you get what you pay for.
  10. Joe Dirt
    I started to buy that kit, then i remebered the mustang i had that the rotor button blew apart and went through the cap and couldnt get parts to fix it even through procomp.
  11. strokermaverick
    Yes, I bought a ready to run distributor from Whites performance on ebay. The only place that I could get a replacement cap was from him. I'm just gonna steer clear of the procomp electronics.Is'nt that ironic, the company is called "procomp electronics". :hmmm:
  12. maverick75
    Theres actually two companies. Pro comp from australia. And pro comp electronics from Canada. They both sell chinese stuff though.
  13. markso125
    markso125 Member
    Lewiston Ut
    1972 maverick 2 door LDO
    the procomp from austrailia was procomp racing and they got sucked up by procomp electric, just like the parker racing was that made the old parker funnelweb down in australia. If you get an australian made funnelweb then it is 100 times the intake that the chinese one is.(but there is also a procomp suspension but it is a different company)
