Play in column..
Discussion in 'Technical' started by blugene, Aug 30, 2014.
  1. blugene
    Is this play normal? I bought it used and I have no knowledge of these columns.
  2. tody
    tody Member
    cologne, germany
    normal... no bearing on the bottom. when attached to the steering coupler, it'll stiffen up.
  3. Dave B
    Yes.......
  4. car-nut
    car-nut Glenn
    conn.
    You can replace the bearing and it will be perfect!
  5. mav1970
    Self centering when bolted to the steering box :)
  6. Dave B
    When you take them apart, there are some nylon guides, but nothing really holding it in place.
  7. 71gold
    if this is the one you are using with the rack n pinion...don't worry about the play.
  8. blugene
    Thanks guys..
    Yes. It is..
