Phil Mitchell
Discussion in 'New Members Forum' started by phil440, Apr 1, 2006.
  1. phil440
    phil440 Member
    UK
    Maverick
    Just a few more picutres of my maverick,also the only other one in the UK.
  2. Jamie Miles
    Alto, GA
    I've had a few
    Looks good! Looks like you are missing the panel that goes between the front bumper and up under the grille.
  3. phil440
    phil440 Member
    UK
    Maverick
    a few more pics
    a few more pics :tiphat:
  4. Hawkco
    Hawkco Genuine Car Nut
    Rex, Georgia (GA)
    77 Maverick
    Nice looking car! You've got to post some details - how's it equipped, what times does it run, etc.:clap::clap:
  5. sierra grabber
    sierra grabber Certifiable
    northern nevada
    very nice car. as for the only other in the uk. there is another. he is a member of the board, and his car is currently in a black primer. he was looking for parts cheap and shipping. I also see there is a nice green duster over there(y)
  6. don graham
    welcome to the board. nice cars.:Welcome:
  7. Mercurycruizers
    Venetia, PA
    :Welcome: to the board. Nice looking Maverick...
  8. fan2488
    fan2488 Member
    spring,TX
    1969.5 maverick, 1972 grabber
    welcome aboard
  9. sierra grabber
    northern nevada
    check out the member named survival276. he is in london and putting back together his mav with right hand steering(y).
  10. DonO
    DonO Member
    Xenia, Ohio
    1972 with mild 302
    The cross walk signs look just like they do in the USA....
  11. sierra grabber
    northern nevada
    now that you mention it, the stoplight in the background of that pic is on the wrong side of the road for the UK.:hmmm: maybe that one was taken before it was shipped over.
  12. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    Ha! Love the one of you holding two 'bottles of throttle'.
    I'm with Hawkco, what are the numbers?
    And Welcome Aboard.
  13. phil440
    phil440 Member
    UK
    Maverick
    1974 302 Ford Maverick Grabber
    Gearbox is 3 speed automatic C4,with full reverse manual shift kit fitted
    New parts as follows: Heads have been flowed and decked
    Oil filter Crank reground
    Oil pump drive Oil holes chamferd
    Cam chain set Valve stem seals
    Big end bearings Bronze inserts
    Camshaft
    Lifters Block:Rebore +30,Honed & Lifter bores
    Valve springs Boiled and crack tested
    Pistons 10-1 +030 Headers and inlet manifold port matched
    Piston rings to cylinder heads
    Core plugs
    Rod bolts Body:
    Valve locks Fiberglass boot/bonnet/bumpers/dues
    High volume oil pump fasteners
    Electric fuel pump Wheels:10.5 and 3.5 centreline
    Emergency cut-out
    Electric Line-Lock Axle:Ford 8 inch with 4-11 gears by
    650 double pumper John Webster
    Accel distributer
    New turbo mufflers Tube front end with coil over shocks by
    Exhaust cut-outs John Webster
    Most of engine work by I.C.E
    Lots of recpiets from work done
    Bump stop removed
  14. streetrod77
    streetrod77 Member
    Memphis,Tenn
    77 comet
    Nice...lol...very nice...those 2 containers have more power than most imports around here...lol
  15. sierra grabber
    northern nevada
    :rolleyes: bump stop removed :lolup::biglaugh: .
