Performer RPM Heads Help..
Discussion in 'Technical' started by Scotty P, May 28, 2005.
  1. Scotty P
    Scotty P Member
    santa rosa, ca
    OK, so after several EBAY disasters I got my heads! After reading the instructions (don't tel my wife!) and they talked about drilling "steam holes" into the block to access water jacket! Anyone do this? I believe my block is a 71. They said late models do not need this done, Somehow I don't think they view a 71 as a late model. Thoughts????
    Also, what plugs can I get locally for these heads? What are you guys running?
  2. courier11sec
    courier11sec Member
    Tucson, AZ
    What's your compression going to be? I run 3924 Autolites in mine Scotty. My block is a 1968 and I didn't drill any holes.
    Would't mind having a look at those instructions. I don't remember anything like that with mine, but then I really don't remember any instructions.
  3. Scotty P
    Scotty P Member
    santa rosa, ca
    10.33 will scan instructions tommrw. Is that a peanut plug? the smaller style?
  4. courier11sec
    courier11sec Member
    Tucson, AZ
    It's a 5/8 head, crushwasher type and fairly deep threads. about 3/4" reach.
  5. Scotty P
    Scotty P Member
    santa rosa, ca
    hoping for smaller head. Pain with the tubes! Thanks..Firing up Monday, I hope!
  6. Mavaholic
    Call up Eddlebrock. I'm sure they have a tech line but if not, I'm sure they would be willing to help anyway they can.
  7. mavman
    mavman Member
    Arkansas
    3924's work great...clears everything. Be forewarned...if your heads are the later style with deeper spark plug location, they will hit the piston domes with those plugs and TRW L2249NF dome pistons. Works great with flat tops though! You can use either the 3924, 3933 (race plug) or Motorcraft AGSP32C...which I believe is made for 2.0 4 cylinder....but they work! They're all 5/8 head 3/4" reach, but the 3933 is a little colder (race plug of course).
    Oh...and no, you don't have to drill the steam holes. Works just fine without them.
  8. Scotty P
    Scotty P Member
    santa rosa, ca
    Thanks all. Have flat top pistons so no ussue there. Looking forward to "feeling" the new heads in the seat of my pants! I will not drill any holes, seems odd. I will post the instruction sheet scan after I leave the office..Great weekend all...
  9. Comet155
    Comet155 Member
    My block is a 71 also. I was going to install Tricks and went ahead and drilled the block steam holes (3/16's). Then decided on different heads (Jeg's) and didn't need to drill the holes because the Jeg's heads do not have the corresponding holes. So check your heads first...drill the block only if the heads have the steam holes. Otherwise just skip it.
  10. don graham
    edelbrock told me to use champions. can't remember which ones offhand. car ran so lean at the et finals in bakersfield i burnt the electrode right off the #1 plug. was told to try an autolite AR3910. they run great, but the car is a track only car. not sure how they'd do on the street.:)
  11. Scotty P
    Scotty P Member
    santa rosa, ca
    This is what I was referring to. Don't thnk I will drill any holes
  12. Scotty P
    Scotty P Member
    santa rosa, ca
    Diagram to drill
  13. courier11sec
    courier11sec Member
    Tucson, AZ
    Not a very precise diagram is it? Sheesh!
  14. stockhatch
    stockhatch Re Member
    Boiling Spring Lakes NC
    '72 Grabber
    Im pretty sure head gaskets have the holes in them, so I believe you use the gasket as a template. Im still not sure why you would have to do this though...
  15. v8maverick
    v8maverick Member
    Delaware
    1973 Maverick, 1972 Grabber
    There is three 3/16" holes (intake side) on the head gasket for each cylinder, the older block and heads use the center hole, newer heads use one of the other holes ,so with your heads off put a head gasket on block and see what hole it uses (old block center hole) then take the head gasket and put it on the head and see what steam hole it uses, it needs to be the same as the block if not you got to drill the 8 holes (some after market heads can use either holes). You can do this with engine in car but is tricky, need to wipe down block gasket surface with MEK or other solvent and tape up cylinders and intake valley so no metal chips get in (I found that aluminium duct tape works good) also have someone hold a vacuum at each hole while you are drilling, make sure to deburr the holes, DOUBLE CHECK you are drilling the correct holes (right or left of center hole) and take your time !!! one more thing you can use a 3/16" drill bit instead of 1/8" Hope this helps.
