Painting Grille
Discussion in 'Cosmetic' started by greenwa1, Jul 4, 2010.
  1. greenwa1
    greenwa1 Member
    El Paso Texas
    72 Comet GT, 71 Maverick
  2. 71nogo
    71nogo Member
    tucson,az.
    71 grabber
    I cant speak for any one else but i shot my grill on my mav, flat black with rustoliem.
  3. predfan2001
    I've always used a Scotchbrite pad. They grey ones I think. No way you'd ever be able to get into all of the openings with paper imo.
    Ditto on the Rustoleum but I think I used satin or semi flat....it holds up great. I painted my 70 grille in the 80s and it still looks good.
    I sprayed my headlamp doors and them got a rag and some laquer thinner and carefully removed the paint from the edges before it was completely dry. I tried taping it off but it is too much work.
  4. 71nogo
    71nogo Member
    tucson,az.
    71 grabber
    taped mine with painters tape. took about 5 mins.
  5. predfan2001
    Thinner and a rag took about 2 minutes....I'm lazy! :rofl:
  6. 71nogo
    71nogo Member
    tucson,az.
    71 grabber
    right on. ill try that next time.
  7. greenwa1
    greenwa1 Member
    El Paso Texas
    Will use the scotch brite pad to scuff up the grille. I have to make a couple of repairs and was sondergin what grit sandpaper to use to smooth them down.
  8. bmcdaniel
    Soap and water, scotchbrite pad, Rustoleum Satin black.
  9. greenwa1
    greenwa1 Member
    El Paso Texas
    When I make the repair I will have to use something to sand it down besides a scotchbrite pad. 280 or 300 grit maybe to get it even?
  10. Jsarnold
    Jsarnold Senior Member
    Raleigh, North Carolina
    '72 Sprint
    Is the Rustoleum Satin Black a paint for plastic or did their metal paint work OK? Don't know if Rustoleum makes a plastic paint but I don't want to use the wrong stuff and create a problem.
  11. darren
    I repaired my grill with 3m panel bond adhesive. Likely the same idea as what your using. It worked great. I even built up areas that were completely broken off. Took some time to get it looking right but it worked out great. Mounts are stronger than new. I scuffed mine with scotchbrite as per our body man. Gave it a real good cleaning with silicon remover. I painted it with Mar Hyde trim paint as per our body shop. Its supposed to stand up to UV and not fade out. Been almost 2 years now and it looks same as the day I sprayed it.
    [ame="http://www.amazon.com/Paint-Black-Aerosol-TSL3811-Category/dp/B000HUNXD4"]Amazon.com: Mar Hyde&reg Trim Paint Black Satin 12 Oz. Aerosol (TSL3811) Category: Paints: Automotive[/ame]
    A little side note. When I installed my grill I used plastic push pins to mount it intead of the factory screws.
    I found when I work over the front of the car i lean on the grill. The push pins allow me to pop the grill off in seconds so I dont crack it.
    http://www.google.ca/imgres?imgurl=...&ndsp=21&ved=1t:429,r:1,s:60&biw=1280&bih=568
  12. Jsarnold
    '72 Sprint
    Thanks for the info and thanks for the link. :Handshake I ordered the paint. Like ordering from Amazon. Its easy and prices are usually pretty good.
    Good idea on the push pins too. I'll put it on with screws till I can pick up the right pins.
