painting bumpers
Discussion in 'Cosmetic' started by JD71, Jul 11, 2008.
  1. JD71
    JD71 John Kenney
    mississippi
    71 maverick
    How can i go about painting my bumpers and how much would it cost
  2. Mavman72
    Sand the chrome with 220 grit,Apply a good etching primer(Vari-prime is a good one)Then use a good 2 part primer surfacer.Block sand/wet sand untill you have a smooth surface,perhaps prime some more if necessary.Repeat sanding steps,finish up with 400/600 grit wet then clean/dry and paint whatever color you want.The key is scuffing the chrome well so paint will stick to it.The only thing that naturally sticks to chrome with out coming off is bug guts...good luck.
  3. Acornridgeman
    Wisconsin
    John - is this for those really nice chrome bumpers on the car in your avitar? If so, you may want to grease them up and store them for future use and go with a set of fiberglass ones. The run about $125 bucks each and are quite easy to paint.
    http://www.up22.com/amx68.htm#MA-110
    This way - you could go back to chrome someday if you wanted.
  4. JD71
    JD71 John Kenney
    mississippi
    71 maverick
    I wish that was my car. the pic of my car was too big to use. my bumpers don't look that great. and i'm kinda lookin for the cheapest way out
  5. Mavman72
    You could just sand em and spray bomb them,but you will be doing it once a year at least.
  6. 302mav76
    302mav76 Isaac Serna
    Monterrey, Nuevo Leon, Mexico
    '76 Maverick
    I guess the fiberglass bumpers are the way to go. They're lighter and cheaper.
  7. maverick1970
    maverick1970 MCG State Rep
    Missouri
    That is one of Ray's (Razorsharp) cars (prior to Katrina) in the avatar.
    I had my bumpers sand blasted prior to priming and painting.
  8. Acornridgeman
    Wisconsin
    (y) - I thought it looked familiar
    Sandblasting seems like a good way to go. Adhesion of the new paint is critical to prevent stone and bug damage.
  9. maverick1970
    Missouri
    Mine have been painted for 24 years and the paint is still on there.
  10. hotrodbob
    hotrodbob Member
    Central Coast, So.Cal
    Sold my 1971 Grabber
    Or ya take them to a chrome shop and they can dip them and remove the chrome leaving bare steel.
  11. rayzorsharp
    Yup...looks familiar to me too. :rolleyes:
    Poor thing...still sitting in the back yard. Not sure if or when I'll be able to do anything with that one. Too many projects.
  12. newtoford
    newtoford Member
    New Castle Delaware
    my buddy just used lime from the local farm supply store to strip the chrome off an old set of dodge dart bumpers. he swares by the technique
  13. Dave B
    If it'll take the chrome off like that, keep your fingers out of it! :D
  14. MavJoe
    MavJoe Certified Lunatic
    Sacramento, CA
    1971 Maverick Grabber
    I've been contemplating this myself, still not sure whether I should paint them or rechrome them.
    Whichever is the cheapest route I guess would be the best, mine have surface rust spots that need to be dealt with first.
