painted grill
Discussion in 'Cosmetic' started by RobbieG., Feb 9, 2010.
  1. RobbieG.
    RobbieG. Member
    Phoenix Az.
    75 Maverick, 72 Maverick sprint, 67 Mustang bracket car, 02 F250 4X4
    I have a real nice grill for a 71 but the guy who had it painted it PURPLE!!
    Whats the best way to get the paint off without hurting the grill?
  2. mojo
    If u want to repaint the grill. I wud just clean it, go over w\ fine steelwool and repaint it whatever color I desired. I wud hesitate to use any harsh chemicals to strip it. Maybe some of the water based new strippers may not harm it -- but that might be risky IMO.
    GUD LUCK WITH IT...
  3. RobbieG.
    RobbieG. Member
    Phoenix Az.
    it looks like it has about 3 layers of paint on it and they are chipping.
    it's a mess
  4. mojo
    Well! I don't know what else to say on that. I guess ur options are limited. You may not have much else of an option but stripper. Maybe some of the folks here can offer some other suggestions.
  5. Bryant
    try talking to the people at an automotive paint supply place. they should know there products and what will work best for you.
  6. sgaugeguy
    sgaugeguy Bob Kraus
    WILLIAMSTOWN NJ
    I have used original Easy Off Oven cleaner to remove paint on plastics in the past and it worked great. Sprayed it on and left it a while then hosed it off and all the paint just washed off.
  7. RobbieG.
    RobbieG. Member
    Phoenix Az.
    That sounds to easy!! I'll have to try it.(on the corner, in the back..LOL)
  8. Acornridgeman
    Wisconsin
    Go to an auto paint dealer and get a product like this:
    Aircraft stripper for plastics - This is what I have used very successfully. SEM also makes a paint remover for plastics but I have not personally tried it. I know we are talking about a grille, but for small parts, soaking in DOT 3 brake fluid overnight works wonders.
    :Handshake
  9. SERE Guy
    SERE Guy Member
    Fairchild AFB, WA
    '73 Mav w/ 302
    I've used Easy off on plastic with great results. I was unaware there was an aircraft stripper for plastic. If its half as good as the regular stuff, I'd use that. A bit pricey, but quick.
  10. RobbieG.
    RobbieG. Member
    Phoenix Az.
    Thanks for your help. I know what i will be doing this weekend.
