ow hot does your car run
Discussion in 'General Maverick/Comet' started by JHodges, Nov 12, 2009.
  1. JHodges
    JHodges thumper
    Dora Alabama
    I was wondering how hot a basically stock 302 should run
  2. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    Mine runs about 190 degrees, with a 185 degree thermostat. It also ran that without a thermostat. Stock new 2 row rad, with a Ford flex fan.
  3. PAINTANK
    PAINTANK Cometosis Obsessivus
    South Central, North Carolina
    1973 Comet 2 dr
    I am installing a 195 degree thermostat in it this weekend.
  4. scooper77515
    Mine runs 180, sometimes if traffic is bad and weather is not cooperating, 185.
    Aluminum 3-row radiator, 180 degree high-flow thermostat, electric fan on a thermostatic switch, and several years worth of fighting a high temp running engine.
  5. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    aluminum 3 row . . . with electric fan 195, without electric fan 197 but of course it'll heat up a lot higher in traffic without the electric fan.
  6. Joe Dirt
    190* on a 195*& stat
  7. scooper77515
    the stock radiator will not take much in the way of modifications before it cannot keep up the cooling power to keep an even moderately modified 302 cool.
    I said "mod" too many times in that sentence. I moderately believe I should modify that sentence before a moderator comes in and deletes my post...:rolleyes:
  8. Jamie Miles
    My 200 stays around 190-210 or so, and that's where I like it.
  9. justin has a 74
    kentucky
    same(y)
  10. Earl Branham
    Lugoff, SC
    Running a 160 degree stat, Taurus fan. Runs at 170degrees all the time.
  11. darren
    Mine runs 190-195 with a stock radiator.
  12. JHodges
    JHodges thumper
    Dora Alabama
    my car hit about 210 driving it and it would drop to 190 if I sped up. I have a 192 thermostat in it now. I am planning on putting a 160 thermostat in it to see if I can cool it down
  13. justin has a 74
    kentucky
    I think that would be too low, mabey 180?
  14. DaMadman
    Southern MD
    Maverick 1972,1970,1973
    My V8 has a 160 degree thermostat and it runs about 155 - 160 ALL the time. traffic hot weather the whole 9 yards it doesn't matter. I have one of the Champion Alum. Radiators.
    My 6 cyl. has the same radiator and it has a 185 thermostat and it runs right around 180
  15. bikerbuck65
    bikerbuck65 Member
    california
    maverick
    Ive got a 160 stat electric fan,alum 3 core rad and it all depends on the outside temp, If weather is cool below 90 ill run at 180 -190,If outside temp is over 100 and i run hard my temp will climb to 210-220..
